Old 05-14-2023, 01:31 PM   #1
Battery Disconnection Location
Where is the battery disconnect located on the Geo Pro? I have a 2021 FBS that works fine on shore power, but I think the dealer turned off the battery disconnect when I bought it before winter. Can't locate it anywhere and can't find video that shows where it is located.
Fourthwatch is offline   Reply With Quote
Old 05-14-2023, 02:22 PM   #2
bikendan's Avatar
Moved thread from the Forum Administration/News/Member Accounts section to the Rockwood sub-forum since that section has nothing to do with the OP's questions, which are specific to a Rockwood model.
Sent from my SM-G781U using Forest River Forums mobile app
Old 05-14-2023, 02:47 PM   #3
Geo Pro battery disconnect
My question has been moved to Rockwood forum. I was told by tech that I would not receive any replies until I signed in again, so here I am signing in again and asking for help.
Old 05-14-2023, 03:10 PM   #4
bikendan's Avatar
The battery disconnect switch might be mounted on the side of the A-frame, just under the propane tanks. Probably on the driver's side.
Old 05-14-2023, 03:29 PM   #5
Battery disconnect
That was the first place that I checked, but it's not there, behind batteries on a-frame or inside the storage compartment, or under bed by converter. I'm just looking for something with a red key. Thank you so much though for your suggestion. Any other thoughts would be much appreciated!
Old 05-14-2023, 04:40 PM   #6
I found this info in another thread on this topic:
https://www.forestriverforums.com/fo...on-237447.html
Found it!
Turns out, with this newest model, ours is tucked up under the tongue, forward from the battery some and closer to the jack motor. Who knew! Just glad we found it--only wish it would have been before we decided last night to unhook the battery cable. But hey, at least we didn't drain the battery by letting the fridge run all night. Also found a vid on that and how to set it to 0 and it will keep it from draining battery.
Name: geo pro battery dc knob.jpg
2017 Rockwood Windjammer 3006WK
dankirk is offline   Reply With Quote
Old 05-14-2023, 07:54 PM   #7
Thank you
Thank you!!! You are right... Had to crawl under the A frame and look under propane, but it was there.
Old 05-14-2023, 08:09 PM   #8
Great!!! I hope that solved your issue!
battery, battery disconnect, cat, location
