Don't worry about the TV side
Originally Posted by rebel rouser
I have a 2023 2608BS would like to have a tv mounted in bedroom. Got a call from dealer that the mount that they use lines up the mounting holes on the tv but the mounting plate covers the power cord HDMI and the cable hook up.Was told the mount is actually for a Furrion tv.that costs around 3to 4 hundred dollars for a 24inch.Was told they will look for a universal mount. They said if the plate is modified it could weaken it.
Don't worry about the mounting holes on the TV. The dimensions of those holes are standardized by a standards body called VESA. There are basically two sizes, little and big. (The bigger one is for heavy TVs.) Concentrate on finding one with a wall mount that will work for you.
Larry
