Old 05-30-2021, 05:52 PM   #1
Bike Rack Experiences????
Folks,
I'm (hopefully) getting my new 2021 Rockwood Minilite 2511s in a few weeks. It has the 2" hitch on the rear bumper, capable of handling 200lb.
I want to use it to carry 2-3 bicycles. Clearly the bike rack has to extend enough to go past the spare tire.
Any recommendations on brands people like? The kind that the tires hook into or the kind that you lift the bike onto the bar?
Thanks in advance.
_______________________
2022 Rockwood Mini Lite 2511s
2020 Ford Expedition XLT - Max Towing
jsk125 is offline   Reply With Quote
Old 05-30-2021, 07:22 PM   #2
You will need to get your bumper hitch reinforced. 200 lbs is not enough to accommodate a bike hitch and 2 to 3 bicycles.
2019 Ram Big Horn 6.7 Cummins
2020 Rockwood Ultra Lite 2304DS
RobRockz is offline   Reply With Quote
Old 05-30-2021, 08:22 PM   #3
How heavy are your bikes?!? I’d think that would be more than enough for 2-3 bikes, unless you have a really heavy bike rack.
phipps33 is offline   Reply With Quote
Old 05-30-2021, 08:53 PM   #4
rsdata's Avatar
there are plenty of posts on here about bike racks you may want to explore...
take your average bike rack at 25#
then add 2 or 3 bikes at like 30# each
then extend that weight out a foot or so to clear the body of the RV
then bounce down the road at 70 MPH and think about the stress on that bumper hitch as that nearly 100# of weight bounces up and down on every concrete joint in the interstate and even more when you hit a pothole
you will probably figure out that 200# of weight capability on that hitch is not very safe for your expensive bikes...
But decide for yourself before you do put your bikes on that hitch.
2014 Shamrock 183
Old 05-30-2021, 08:54 PM   #5
There are numerous threads on this you should check out. Folks with experience warn that the bumper TT hitch is not sufficient unless reinforced. This issue is not the weight on the hitch but the torque applied by the bike rack. Some reinforce their bumper and others buy reinforcement brackets, many choices are available at Amazon on other retailers.
2020 2205S Rockwood Minilite
2019 F 150 Lariat 3.5 Eco Fx4 Max Tow
Equalizer WDH, 1809 lb payload
flyflotrtim is offline   Reply With Quote
Old 05-30-2021, 10:14 PM   #6
bikendan's Avatar
I think you'd be surprised how much the average adult bike weighs. My XC full suspension race mountain bike weighs around 25lbs and my expensive road bike weighs just under 20lbs. The average adult bike weighs around 40lbs-50lbs. And ebikes are much heavier.
Old 05-30-2021, 10:39 PM   #7
I believe the post is referring to a 2” receiver which is welded to the frame not the bumper. We own a 2020 Flagstaff that has the 2” receiver welded to the frame rated at 300 lbs. We carry 2 ebikes on a heavy duty Kuat rack. We have traveled several thousand miles with no issues. With that being said it always makes me a bit nervous and I’m considering putting a receiver on the front of my truck, just need to figure out if bikes will restrict vision when driving.
2020 Flagstaff 26FKBS
2020 Ram Tradesman 2500 6.4 Hemi
Csbadvisor is offline   Reply With Quote
Old 05-31-2021, 06:53 AM   #8
I have a Reese hitch that can do 2 or with the extension, 4 bikes. I choose 2 on the Ultralite. I slid my spare tire over so its closer to the frame and less bounce. If I needed to take a 3rd I have a stand up rack I can set inside which also works nice as a bike rack on the campsite.
Dave Stegink is offline   Reply With Quote
Old 05-31-2021, 06:54 AM   #9
Correction, a Reese bike rack!
Old 05-31-2021, 07:06 AM   #10
nomad297's Avatar
Keep in mind that the longer the shank is, the more the downward force of the bicycles increases on the bumper. Add to that the increased up and down motion and force created while traveling.
Bruce
Old 06-01-2021, 08:45 AM   #11
Csbadadvisor - Thanks .. I may have misquoted at 200lb. It probably is 300lb, and from the version I saw on the lot and in videos - it is welded to the frame.
Old 06-02-2021, 10:08 PM   #12
We're still waiting for our unit to arrive but had a similar need of carrying 2 bikes plus wanted to have room to avoid the spare. Ended up purchasing the Swagman Dispatch which I assembled last weekend and (at least based on measurements) looks like it will work around the spare just fine. The rack itself is heavier construction (about 30-35 lbs) and has slightly longer shank than the Traveller XC2 which is why we went with this one.
Hope this helps
CalgaryRVCouple is offline   Reply With Quote
Old 06-06-2021, 10:19 PM   #13
Roaminaround's Avatar
We use a ratcheting strap from the rack to the ladder to mitigate the bouncing you get driving down the road. The bouncing can easily double the dead weight stress on your rack, bumper and receiver. Logged over 15,000 miles with the strap on our rack with 2 mountain bikes.
Bend, OR
2019 Rockwood 2608BS
2018 Ford F250 6.7 diesel super crew
Roaminaround is offline   Reply With Quote
Old 06-07-2021, 07:44 AM   #14
I looked up ours this weekend. My wife’s Nishiki mountain bike from Dick’s is 65 lbs, my Trek Hybrid was 27 lbs.
PopUpPop is offline   Reply With Quote
Old 06-07-2021, 11:18 AM   #15
Look at the Lippert Jack-It rack system. Fits on the tongue over the power jack.
2021 Flagstaff 21DS
2015 Silverado 2500HD (overkill but convenient)
Renogy bits: 3000W Inverter/Charger, 400Ah LiFePo4, 40A DC-to-DC
Rich Solar bits: 400W of panels, 40A MPPT
Misc bits: LevelMatePro+, SolidRemote based wireless controlled LED storage lighting
jbflag21ds is offline   Reply With Quote
Old 07-26-2021, 11:51 AM   #16
either weld a receiver to frame or get safety struts
https://www.amazon.com/Mount-n-Lock-.../dp/B084ZTHPTK
2017 Mini Lite 2506S front kitchen
2018 GMC Sierra 1500
labcamper is offline   Reply With Quote
Old 07-26-2021, 12:06 PM   #17
camper_Lucy's Avatar
X2
2019 Chevy 3500 4x4 Crew Duramax
2021 Gray Wolf Toy Hauler
2019 Street Glide
camper_Lucy is offline   Reply With Quote
Old 07-29-2021, 10:31 AM   #18
I put an eyelet at the top of our Swagman rack and use two ratchet straps down to either corner of the frame, that keeps it from bouncing or moving much at all. I had (doesn't work now) a rearview camera and they did not budge over the biggest So Cal freeway dips and drops.
My receiver is aftermarket and welded to the frame. OEM had folding rack that I remove when not needed and it is rated for 300# so I'm very safe with two bikes and a rack. This is what works for me. E bike is next.
nayther is offline   Reply With Quote
Old 07-29-2021, 11:02 AM   #19
Too Tall's Avatar
I would get a hitch that attaches in 2 points. I wouldn't use the single point receptacle. Remove your spare tire and put it in the truck bed. That way your net weight gain is minimalized.
Rockwood 2104S, 2014 Ram 2500 Diesel.
USMC 68 -70
Too Tall is offline   Reply With Quote
Old 07-29-2021, 11:54 PM   #20
We have the 2” receiver on our Rockwood 2608BS. I have a Swagmann bike rack that I purchased from eTrailer.com. It is approved for use with an RV and extends out beyond the spare tire. We just completed an 1800 mile trip with two bikes and had no problems with it. This is the link to it: https://www.etrailer.com/Hitch-Bike-...man/S44FR.html
2020 Rockwood 2608BS
2017 Wildcat Maxx 26BHS
2016 Rockwood MiniLite 2503S (2015-2016)
2012 Ford F-150 Eco-Boost
2021 Ford F-250 Super Duty
OscarsMom2 is offline   Reply With Quote
bike, bike rack
