Old 02-26-2021, 09:07 PM   #1
Blocking the sun and full moon
Hey, what’s everyone using for a shade over the shower skylight. I know it should be something somewhat water resistant and easy on and off. Tried one of those foil bubble wrap but it did not last long at all. Any ideas would be appreciated.
Lcdjbd. 2017 Rockwood 8244WS
lcdjbd is offline   Reply With Quote
Old 02-26-2021, 09:31 PM   #2
I kinda like having a little sun shining in when I shower.
Iwritecode is offline   Reply With Quote
Old 02-26-2021, 09:34 PM   #3
Thanks, but I kinda like sleeping in and no full moon at night
Old 02-26-2021, 09:35 PM   #4
In previous threads folks have suggested window tint film, and a light coat of white paint on the outside of the skylight.
Personally I also like the light shining in.
2205S Rockwood
F 150 Lariat 3.5 Eco Fx4 Max Tow
Equalizer WDH, 1809 lb payload
flyflotrtim is online now   Reply With Quote
Old 02-27-2021, 06:44 AM   #5
nomad297's Avatar
Go to this link and scroll down to the post by “Wadcutter”. This is a simple and effective solution:
https://www.rv.net/forum/index.cfm/f...print/true.cfm
EDIT: I have no idea if linking to another RV forum is an okay thing to do here. I have never done it before, so if my post has to go, I understand.
Bruce
Old 02-27-2021, 07:23 AM   #6
Duoform Plastics Skylight shade SLS 1422B,looks Factory and blocks outside light while also reflecting heat from Mr Sun! Youroo!!
Old 02-27-2021, 11:16 AM   #7
Thanks for the reply. Extension rods are going to be my fix. Lcdjbd
Old 02-27-2021, 02:03 PM   #8
Dahagen
Have you tried closing the bathroom door?
dahagen is offline   Reply With Quote
Old 02-27-2021, 02:24 PM   #9
Bathroom OR Bedroom sky light???????????????
Jim in Halifax is online now   Reply With Quote
Old 02-27-2021, 02:34 PM   #10
My wife didn't care for that much sun coming in, so I used a lens tint spray. Did the trick. Rust-Oleum and VWT (probably others) offer the product.
grport is offline   Reply With Quote
Old 02-28-2021, 05:10 AM   #11
I have the Duoform. I think around $70. Looks factory. Installs in 10 minutes. Has retractable shutter to block or let in light. Over a year old now. Stays clean and works perfectly.
Rusty
2019 Riverstone Legacy 38MB
Full Paint Merlot/All Options
2015 Black Ford Platinum Diesel F-350 Dually
lcv800 is offline   Reply With Quote
Old 02-28-2021, 05:53 AM   #12
I cut up a blue foam pad made for backpacking. It provides a little insulation and protects the shower from UV while in storage. It is just a press fit, but it is stiff enough that it stays up.
mnoland30 is offline   Reply With Quote
Old 02-28-2021, 07:52 AM   #13
Homebrew's Avatar
How about something simple like a eye shades, many people wear them to block light while sleeping.
Also some people just jam a foam pillow in the opening, this provides insulation and blocks the light.
XLR Thunderbolt 300X12HP
2014 Ram 3500 DRW
Homebrew is offline   Reply With Quote
Old 02-28-2021, 10:30 AM   #14
Trailer Park Supervisor
NJKris's Avatar
I bought this to shove up into skylight recess over shower. Haven't used it yet, other than to ensure it fit. Easy enough to pull out when you shower so it doesn't get wet/moldy. Good deal now, 5 bucks less than when I bought it.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
NJKris is offline   Reply With Quote
Old 02-28-2021, 03:19 PM   #15
Looking at the floorplan for the trailer listed in the OP's post is appears there *is* no bathroom door. The shower is literally in the bedroom.
I'm not sure I've ever seen that before.
Old 02-28-2021, 03:42 PM   #16
I've seen that on a few rigs and there are pros and cons to stepping out of the shower into the bedroom. Obviously a full moon or any other light source that shines through the skylight at night is a negative.
It would be interesting if the OP posted a picture of his tension rod solution once it's installed.
2015 Dynamax REV 24TB class C
Reverse_snowbird is online now   Reply With Quote
Old 02-28-2021, 04:09 PM   #17
When I had my 5er I cut two pieces of vinyl siding channel to fit the long way. Then I cut thick cardboard to slide into the channel. You can double up the cardboard if necessary, and run some duck tape around the edge to help give it a tight fit. It worked great, wife was very happy
2018 GMC Sierra 1500 SLT
2005 Keystone Cougar 245 (sold)
2021 Coachmen Apex 265RBSS (on order)
2011 GMC Acadia SLT (wife’s)
2007 Honda Goldwing
Marc J is offline   Reply With Quote
Old 03-07-2021, 07:33 PM   #18
cheap 12 x 12 pillow or whatever size fits the hole.
Insulates as well as blocks light.
Use your money for more important things like Beer
campers302 is offline   Reply With Quote
lock
