Old 09-28-2020, 08:42 AM   #21
Old Forester's Avatar
Our 2016 Windjammer 3029 came from factory with the upper baffle. I put two 120mm muffin fans behind lower fridge vent cover to suck in outside air and also installed 2 small centrifugal blowers in the upper vent that suck the air out. I used the existing on/off bimetallic button switch that fed 12v to the original two terrible little tiny muffin fans that had be located half way up on a board between vents and had failed within one year due to being mounted flat. Fridge is amazing now, even on 97 degree days - no issues and QUIET too.
Old Forester is offline   Reply With Quote
Old 09-29-2020, 12:48 AM   #22
TheWolfPaq82
Originally Posted by TheWolfPaq82 View Post
This is a 2020 Rig.....guessing it's new off the lot.
He has a 2016 that doesn't have the board. The rig with the board is his sister's 2020 rig. ( Check post #1)
The answer seems to be that he needs the baffle board. If he didn't buy it new, it's possible someone removed it for whatever reason.
2015 Dynamax REV 24TB class C
Reverse_snowbird is online now   Reply With Quote
Old 10-01-2020, 07:37 PM   #23
XPLOR
Xplor's Avatar
See this video... I added a baffle to mine...
https://youtu.be/ZHgOVrjibZ4
2021 Rockwood Mini Lite 2109S
2018 Ford F150 Raptor
Xplor is offline   Reply With Quote
Old 10-01-2020, 08:14 PM   #24
code.org
moff34's Avatar
Originally Posted by Reverse_snowbird View Post
Sounds like our experts are telling you to leave it in.
The next question would be... are you the original owner of your rig? If not, the previous owner might have removed it thinking that it was a mistake. Otherwise, you might want to consider putting in a baffle.
Yes, original owner.
Guess I will be retro-fitting mine so it has the baffle.
Thank you everyone for your input.
Randy, Mary, and Mojo
Rockwood Signature UltraLite 8329SS
2001 Dodge Ram 2500 Cummins Diesel / Allison Trans
2015-14 Nights, '16-90 Nights, '17-101 Nights, '18-146 Nights, '19-76 Nights '20-56 Nights
moff34 is offline   Reply With Quote
Old 10-02-2020, 01:11 PM   #25
Kimo7's Avatar
We purchased a 2020 Rockwood Signature 8329SB in early February this year. It has a Dometic fridge and also had a piece of wallboard in the same place. It wasn’t wood, it looked like a scrap piece from the interior walls. After researching on the internet and finding some YouTube videos on the subject I removed it and installed 2 computer fans to move more air since the fridge wasn’t getting cold. I also installed fans inside the fridge from RV Cooling Unit Warehouse and it now stays super cold. I pasted the links below.
https://youtu.be/urVLYzf-7jA
https://youtu.be/DzqxBgSR9ZM
https://rvcoolingunit.com/Dometic-Ev...-P5444060.aspx
2020 | Rockwood Signature | 8329SB
2019 | RAM Laramie 2500 | 6.4 HEMI
Kimo7 is offline   Reply With Quote
Old 10-05-2020, 07:29 PM   #26
Originally Posted by TowPro View Post
the factory did this. this is a refrigerator in a slide, your showing the top vent. in order to have the cabinet act like a chimney they had to put a top and bottom vent on it since you can't have a roof vent on a slide.
they discovered that without this baffle the air would swirl as it tried to exit the top vent causing higher temps on backside of refrig.
By reducing the top opening it actually causes more draft through the cabinet.
They started doing it on Open Range RVs around 2011.
I performed this very mod myself this summer. 👍🏻
jorn is offline   Reply With Quote
Old 10-05-2020, 08:45 PM   #27
I own a 33IK Cedar Creek and it also has the board in place, I think it must be there for a reason but not so sure. My camping buddy has 2015 Cedar Creek and it also has the board covering part of the vent. I was looking to remove the noisy fans and replace them with some that aren't as noisy and noticed the board.
skippy84341 is offline   Reply With Quote
Old 10-06-2020, 12:14 AM   #28
NXR
NXR's Avatar
Originally Posted by moff34 View Post
Thanks. That makes sense. However, as mentioned, my 2016 Rockwood which has a very similar floorplan, including the exact same driver's side slide with a Dometic fridge located in it, two side wall vents, and no roof vent, does not have that baffle.
Anyone else have a newer Rockwood with that baffle?
For what it's worth, Norcold requires the same baffle in slide-mounted fridges.
Does the 2016 have the slanted baffle at the top to direct the air sideways? It looks like it's there in the picture.
Ray
2020 Georgetown GT5 34H5
NXR is online now   Reply With Quote
Old 10-06-2020, 01:24 PM   #29
HeavyPuller's Avatar
I took mine out added a small 110v fan directed upward that I plug into an outlet when refer is in use. Makes a high difference in cooling.
HeavyPuller
HeavyPuller is offline   Reply With Quote
Old 10-06-2020, 01:35 PM   #30
Indy815's Avatar
I have a 2019 8329SS. I have this board in my top vent. I cut part of it out to add two computer fans with a remote and a thermostat. The little fan that factory installed wasn't doing the job. Lots of air flow now and fridge is performing much better.
Indy815 is offline   Reply With Quote
Old 10-12-2020, 11:01 AM   #31
FYI I have the same "board" on my 2020 ePro. It's a clever way to force airflow over all the fins before exiting the upper vent...
Name:	Upper Fridge Vent Board.jpg
BunnyCamper is offline   Reply With Quote
dometic, vent, fridge, lock
