I bent both rear ones as I forgot to crank them up before moving. Was able to straighten them enough to use. I use a 2X10 under each jack which seems to work even on the softest sites. I retighten them as needed.
Still new here, but I just had an idea. Has anyone after bending them came up with a slip in shoe type replacement? That's what I will do if on gets bent and need to be replace is make it so the new one can slip into place. I don't like the look of them hang so low on the back and you can drag them off. So why not make the new jack just slip into place after you get to your destination? Once at the camping spot slip the back jacks into it there slot and that it that. Before you hit the road take them off. Has anyone made this yet???????????
Got are first TT, a 2017 2506S. TV, 2016 GMC Canyon Duramax Diesel Loving it!
I don't know, but it is a very good idea. I decided instead, to remove my front pair, two bolts hold each), and then re-bolt the stabilizers upon arrival. I have already replaced one, and I have a spare set.
Surveyor 251RKS
