Originally Posted by Mhb
Two white valves, both on the back side of water heater. Turn both on or off depending on using unit or winterizing
Mhb... you must not have read the post directly before yours?
The OP has a Nautilus wet bay where the valves for the water heater are NOT located behind the water heater itself but rather on the Nautilus water control center. Not all R/Vs are built the same.
