05-23-2011, 03:15 PM
Calgon water softner
What amount of calgon softner(powder) are you's using in each holding tank? Thanks
05-23-2011, 04:52 PM
I use the liquid Calgon, one capful in the black tank and a gallon or so of water AFTER you dump the tank, or at home BEFORE traveling to the campground. That way, it gets sloshed around in there and provides a slick coating to the insides of the tank. I would mix that powder with water in a bucket first, then dump it in the tank. I've always used the liquid style, so I'm not sure of how much powder to use each time. On the box, it should indicate how much to add to a load of clothing in the washer, I would add that amount, or if your holding tank is rather large, 50 gallons or more, maybe double that amount. Just guessing though, so try experimenting yourself. ANY Calgon is far better than none!!! Randy
05-24-2011, 05:35 AM
Grumpy Old Member
What's the purpose of the Calgon treatment for the tanks? I'm guessing from your notes, some sort of lubricant for the tank walls?
CZ
05-24-2011, 05:46 AM
calgon
And if you use calgon ..should you also be using the blue stuff that keeps odor down and helps to break up the waste ???
05-24-2011, 06:10 AM
For whatever reason, the liquid version cannot be found around here (Ontario). Even the powder version is difficult to find - Loblaws stores and the likes (Great Canadian Superstore for example) carry it.
I use 1 cup (more or less) mixed with warm water and to dissolve it, then pour this down in my toilet along with 1-2 gallon of water, after I dump and before I head back home. I also do the same with a cup or so of clothes detergent, no particular brand, just the cheapest. I'll park my trailer for up to 3 weeks sometimes, and foorget about it. Camped on a dozen occasions last year, same ritual, no problems, no odors and decent readings on the displays.
I have never used any anything else, no chemicals, nothing.
If you do a search you will find many discussions on this chemical free method - keep in mind though that Calgon is 'some' chemical...
Good luck,
Denis & Diane
* Happy Campers *
05-24-2011, 06:18 AM
I think the chemical's job is to control odors mostly.
As what we have are 'holding tanks' and not septic tanks, there is no need to break down the waste, you only need to evacuate the stuff when full.
As mentionned on the previous post, I have never used the blue stuff: I use Calgon and some detergent, that's it.
Denis & Diane
* Happy Campers *
05-24-2011, 06:24 AM
CZ
From what I have read in the past, Calgon is used by people in their Black tank to help keep the sides lubricated so the "stuff" doesn't stick to the inside of the tank. Its part of the Geo Method. I don't know why its called the Geo Method.
Scott
DW, 3 Kids and our Goldens
2012 Shamrock 233S
2008 Toyota Sequoia 5.7L 4WD
05-24-2011, 02:09 PM
I've been using a capful of the liquid style Calgon fot 3 years now, and never need the blue stuff or any other deodorizers. I have never noticed any foul odors, except maybe when the tank is very full, and you open the flap.
The purpose of the Calgon is that it acts as a water treatment to put a slick coating on the inside walls of the tank, so that nothing wants to stick to the plastic walls of the tank, thereby producing foul odors and an incomplete dump when empying the tank.
If anyone is familiar with "soft water", as we here in Florida are all too familiar with,(we have a lot of minerals mostly lime in our wellwater) a Water softener machine treats the incoming water into the house to give you the feeling that the soap won't rinse off completely. To shorten the story, that is precisely what Calgon does to the inside of the tank, and why it helps the RV'er. I personally do not have a tank rinser either, never felt I needed one. Hope this helps clear up the Calgon mystery! Randy
05-24-2011, 05:35 PM
(Kim)
Good luck,
I saw some at Walmart.
2010 Dodge Ram 1500
2012 Rockwood 2306
Kim
DH (Alan), DD (Madison) and Zoey the lab,
05-24-2011, 08:41 PM
I just purchased 3 at my local walmart.
2008 Silverado EXtCab 6.0 Vortex Max
2010 Forest River Surveyor SV-294
Equalizer 1000 WD/SC hitch
Prodigy Brake Controller
05-25-2011, 03:53 PM
If you use the powdered Calgon just be sure to mix it well before poring it in your tank. I have noticed a couple times when I was less than diligent about mixing it in the pail that it left some crystal residue on the bottom of the pail.
Norm
Capn & Mrs C
Phoenix The Camping Sheltie
2006 Rockwood 8283SS
05-25-2011, 04:48 PM
Has anyone ever seen the liquid version of Calgon in Ontario?
If so where ?
The powder version is available at some Loblaws (not all) and at Walmart too now it seems - will check it out. $8 a box at Loblaws.
Denis & Diane
* Happy Campers *
06-18-2011, 10:04 PM
Was it the powder version you found in Walmart? Or liquid? What department did you find it in??
Roger & Dawn M.
2011 Rockwood Signature UltraLite 8315BSS
2004 Ford Excursion
Nights camped in 2011: 27
Nights camped in 2012: 34
06-18-2011, 10:19 PM
We too use one capful of the liquid from Walmart, haven't seen the powder. We also use a cup of detergent. Only thing we have ever used in our new HTT but did use the blue and other chemicals in previous campers and much prefer this way.
Donna=Me Tom=DH
2 DD's-grown, 1 DS grown, 1 SIL
4 DGD's, 2 DGS, 1 Shorkie-Gidget 4 and 1 Pekingese-Mia 3
2011 Shamrock 23ss
2010 Ford F150 super cab 4 X 4
06-18-2011, 11:16 PM
Roger and Dawn, it's found in the same area as washing machine detergents and spray stain lifters, CLR, Soft Scrub, etc. At least that is where it is at my local Wal Mart. Some people purchase it online, as well, because sometimes it isn't available in their area. Randy
06-19-2011, 02:09 AM
Nope!
The point of the Calgon is that because it helps the tank to empty more thoroughly you do not have the rotting sewage odor problem.
The tank additives are expensive, smell awful, and some are quite bad for the environment.
We have no tank odor and have used the Calgon for almost a year.
***** ***** ***** 2011 Georgetown 320DS new June 2010
days camped in 2010: 61
days camped in 2011: 37 (up to Aug 1st)
06-19-2011, 05:33 AM
We have also only used the Geo Method in our TT for the last year. Never have a smell issue and tanks clean pretty quickly. I have a clear 45 deg adapter I place on the dump pipe before the sewer hose so I can see when it is cleaned. I am probably most anal about tank cleaning (no pun intended!). I have never used a chemical in our tank and have no plans to. When we find Calgon, we buy every bit we can and store it! We also add liquid laundry detergent (a cap full to a cup). Nothing special, just whatever we are using for the cloths.
Kirk, KN1B
2013 Cardinal 3800FL
2009 GMC 3500HD CC LB SRW
06-19-2011, 09:10 AM
(Kim)
Do you let it sit in the tank between trips?
2010 Dodge Ram 1500
2012 Rockwood 2306
Kim
06-19-2011, 09:24 AM
I empty my tanks, flush until visibly clean (then let it run for a while longer). I close everything up, put my Calgon and laundry detergent in, add about a gallon or so of water and then leave it until I flush next. I usually put some Calgon in the Gray tank every few trips as well and let that sit also.
Kirk, KN1B
