Old 04-16-2018, 09:01 AM   #1
Grammar Pedant
67L48's Avatar
Cam Lock Size 2018 Rockwood Mini Lite
I read lots of threads about switching out cam locks, but almost no mention of sizes and dimensions.
Just a heads-up that I took my locks out of my 2018 Rockwood Mini Lite 2504S to measure them. Seems like I had read that most are 7/8". Mine measured out at 1 1/8". I have no idea how standard these are. I would expect that they would all be the same, but I frequently am surprised at some of this.
Anyway, thought this might help for those wondering about the size of the cam locks.
*** Disclaimer: I really didn't intend to start another "why/why not to change locks and where to buy them" thread. I just wanted to augment those existing threads with some technical size info. But, yeah, it's my fault for starting this.
RV: 2018 Rockwood Mini Lite 2504S
67L48 is offline   Reply With Quote
Old 04-16-2018, 09:06 AM   #2
I replaced all mine (except the outside shower), plus my 2nd entrance door, with locks all keyed the same. It's a LOT easier to open stuff now!
And now I've got about 10 extra keys, because each lock comes with 2.
Got mine here:
RVLocksAndMore | RV Locks | RV Keys | Fastec FIC Locks and Keys
2011 Traverse LT, 3.6L, FWD
Old 04-16-2018, 09:19 AM   #3
dbledan's Avatar
Ch751.com posts this as a measuring guide. You can pull your lock and compare sizes including the cam length and offset.
I found most of my locks from rvlocksandmore.com and got them all key alike except for the outside shower which they didn't sell that short of a lock. I can live with 2 keys and leave the 751key inside the water compartment so I only need one key for my trailer.
Good luck and happy camping.measuring_guide (1).pdf
dbledan is offline   Reply With Quote
Old 04-16-2018, 09:22 AM   #4
Chief T's Avatar
My replacement locks arrived Saturday. Will replace on our trip this weekend.
Ordered from here: https://ch751.com/
2012 GMC Sierra 1500 SLT Z71 6.2l aka "Luci"
2020 Grand Design Imagine XLS 22 MLE aka "Desi"
Past: 2017 Prime Time Tracer Air 206
Days camped 2017: 7
Days camped 2018: 15
Days camped 2019: 17
Chief T is offline   Reply With Quote
Old 04-16-2018, 09:54 AM   #5
I converted the locking shower lock to just a twist turn. I can't see any reason at all to lock the shower.
2017 Coachmen 233RBS
2018 Ford F150 Lariat 3.5 Eco
"Common sense is not very common"
babock is offline   Reply With Quote
Old 04-16-2018, 12:58 PM   #6
compartment locks...
I just changed mine.. .measure from behind the key slot area.. *(where you have in your pic), to the lock tab. I'm reading yours at 1 1/8".. that's what I had.. worked well.. easy to do.. found nice tumbler locks, keyed alike on Ebay... also bought rubber covers to keep the weather out... not a costly project.. total about $30..
thom125 is offline   Reply With Quote
Old 04-16-2018, 01:35 PM   #7
7/8" means they are designed for a door that is 7/8" thick. They have about 1" of threading, which is just enough to go through a 7/8" thick door with enough threading to get the nut onto it securely. At least, that is what I have seen with my doors.
captaindomon is offline   Reply With Quote
Old 04-16-2018, 01:51 PM   #8
It also depends on what the cam (locking tab) looks like. Some are straight across and some have a bend in them,
Mine had the bend, but the new ones I bought came with straight ones, so I had to use the old cams on the new locks.
Also, the screws that hold the cam to the lock were different on the old and new ones.
Old 04-16-2018, 05:57 PM   #9
I put combination cam locks on al mine except for outside kitchen and outside shower. Couldn't find any to fit either. At least my tools and cargo are safe from others having the same key as me.
2018 sunseeker 2860DS
ACJC is offline   Reply With Quote
Old 04-17-2018, 02:07 AM   #10
I changed all my locks on my Rockwood 2608ws. I bought mine at home depot and matched the number so I have one key for all the locks. They have different size cam shafts so most can find what they need.
2013 Rockwood 2608ws
2013 ram 2500 4x4 mega cab 5.7 Hemi
US Air Force Msgt retired
Joe-Barb is offline   Reply With Quote
Old 04-17-2018, 11:10 AM   #11
Sparkz's Avatar
Same here
I wanted to replace the locks on my new Rockwood 2104S and found the same thing. 1 1/8Ē. 👍
Sparkz is offline   Reply With Quote
Old 04-17-2018, 03:48 PM   #12
kdp1897's Avatar
This is my next project. My 2618VS had a combination of slam latches and CH751 locks. Wish the factory had keys then alike. Also, my front and rear doors have different keys.
2017 Rockwood Ultra V 2618VS
2017 GMC Sierra 1500 SLT Crew Cab Z71, 5.3 EcoTec V8
Nights Camped: 30 in 2019; 39 in 2018
kdp1897 is offline   Reply With Quote
Old 03-04-2019, 10:58 PM   #13
Can anyone help me?
I have scoured the Internet and this forum for a way to change the cam lock on my slam latch doors. I purchased new CombiCam locks for my latches but I canít figure out how to change it out without going to a locksmith. There is no way to take the latch apart to access the cam. I have attached a couple of pics to see what I mean.
The latch is made by Southco R3
ID:	198123   Click image for larger version
TomLerch is offline   Reply With Quote
Old 03-04-2019, 11:30 PM   #14
I'm guessing you need to pull out those two roll pins.
Old 03-05-2019, 09:19 AM   #15
Grammar Pedant
67L48's Avatar
If you want help on those style latches, it's a great subject for a new thread. It doesn't belong in a 1-year old thread that's specific to the cam lock sizes, though. If you start your own thread, you'll get better help and others may learn from your project, too. Plus, it costs almost nothing to start a new thread.
Perhaps a moderator could manage this? I'd hate to see good info get lost on the back-end of an unrelated thread topic.
Good luck.
lite, lock, rockwood, rockwood mini lite
