Old 07-18-2021, 04:00 PM   #1
RavensRoost's Avatar
Cannot remove water filter housing to install filter.
Left loosey, righty tighty, right? It is like this sucker is glued on. Solutions?
Name:	water filter.jpg
ID:	259343   Click image for larger version
Name:	Water filter with wrench.jpg
RavensRoost is offline   Reply With Quote
Old 07-18-2021, 04:08 PM   #2
jeff64's Avatar
Have you tried with water pump off and turning on a faucet to release pressure?
2016 Flagstaff 27VRL Emerald
14K Equalizer
2020 Silverado 2500HD CC 4X4 6.6L gas 3.73
jeff64 is online now   Reply With Quote
Old 07-18-2021, 04:37 PM   #3
I've had good luck placing the wtench in position and giving it a whack with a short piece od 2x4. Put some folded paper towel between wrench and canister, enough to hold wrench in place without falling, then hit handle. Doing this eliminates having to get both hands in confined area.
I hit the wrench handle about midway between base and tip. More impact goes into loosening with les flex in handle.
As said earlier, make sure ALL pressure is relieved by opening faucet.
When replacing apply some silicone grease (stuff sold at hardware stores for faucet stems) on o-ring and end of canister. Will help with sealing and removing next time.
Do not overtighten. If leaking, replace o-ring.
"A wise man can change his mind. A fool never will."
2004 Nissan Titan
TitanMike is offline   Reply With Quote
Old 07-19-2021, 11:00 AM   #4
The top white part has to be firmly affixed before you whack on the tool, and yes, it's lefty-loosey. Use a silicon grease on the o-ring for future easy release and don't use gorilla strength to tighten it down.
--2005 F350 Superduty Crewcab, 6.0, 4wd, short bed, 3.73 gears;
--2016 Montana 3711FL, 40'
--2014 Wildcat 327CK, 38' SOLD
phillyg is offline   Reply With Quote
Old 07-19-2021, 12:17 PM   #5
dat
dat's Avatar
I haven’t put a filter in ours yet just because of that, it is so tight from the factory that I haven’t spent the time and effort to get it loose, have really been kinda scared that it would break if I put more pressure on it
Rockwood 2614 BS
Sent by string and cans
dat is offline   Reply With Quote
Old 07-19-2021, 02:26 PM   #6
I did have the pump off, but had not figured on the faucet release. Thanks, came right off after the pressure was released.
Old 07-19-2021, 02:30 PM   #7
rsdata's Avatar
you may noticed some "teeth" on the top near the screw ring... these teeth engage when pressurized preventing the housing from unscrewing...
2014 Shamrock 183
Old 07-19-2021, 02:36 PM   #8
I don't believe this PWP filter, (Pure Water Products) has the 'teeth.'
That was the Gen 1 FR1 housings from WaterPur.
Days Camped: '18=51 '19=58 '20=110 '21=98
Old 07-19-2021, 03:03 PM   #9
I ended up taking that entire canister out and bypassing it with some pex hose and shark bite fittings. Those things tend to leak and not worth it in my opinion
2019 Ram Big Horn 6.7 Cummins
2020 Rockwood Ultra Lite 2304DS
RobRockz is offline   Reply With Quote
Old 07-19-2021, 03:46 PM   #10
GEN 1 with the rstchet maybe. I have the later "no ratchet" model and change element every year. Not a single drop of leakage.
2004 Nissan Titan
Old 07-19-2021, 03:48 PM   #11
Just Tryin' to Help
cboss's Avatar
X2. That's the way to go!
Craig & Cath
2017 Ford F250 Lariat, 6.2 gas (2022 F250 Lariat 7.3 gas with 10 speed Xmsn on order)
Equalizer Hitch w/ 4-Point Sway Control
Days camped since 2015(retirement): 1050
cboss is online now   Reply With Quote
Old 07-22-2021, 12:57 PM   #12
Originally Posted by dat View Post
I havenít put a filter in ours yet just because of that, it is so tight from the factory that I havenít spent the time and effort to get it loose, have really been kinda scared that it would break if I put more pressure on it
X2 on our new Mini. I just decided to cut it out/bypass it and go with an external filter... works much better for me and much less of a hassle when blowing out the trailer multiple times towards the end of season.
2021 Rockwood Mini-Lite 2506s
2019 Toyota Tundra/2020 LR Discovery
2018 Male Newfoundland
"No such thing as bad weather, just bad clothing..."
Scottnweeze is offline   Reply With Quote
Old 07-22-2021, 06:59 PM   #13
Roaminaround's Avatar
I was able to use hose clamps as we have the flexible hose when I bypassed our filter. 150 nights without a leak. I agree that external filters are the way to go. I have a tote with a 2 stage filter and my hoses for hookups. I cut holes in each end of the tote so the hoses can run out and I can put the lid back on the tote.
Bend, OR
2019 Rockwood 2608BS
2018 Ford F250 6.7 diesel super crew
Roaminaround is offline   Reply With Quote
Old 07-26-2021, 08:56 PM   #14
Bypass It
Like RobRockz said. Take it out and if you feel you must have filtered water, use and external one which won't hurt your floors if it leaks/fails. I grew up drinking from garden hoses and irrigation water and not dead yet.
Charles Myatt
2009 Duramax w/Transfer Flow Fuel Tank
2017 Rockwood Windjammer 3029
Almost South of the Border
whatsupchuck is offline   Reply With Quote
water, water filter
