I think what timfromma is referring to is the aerator which screws on outlet from the faucets. These can be restricted by debris in the water lines from the manufacturing process. Just as easy to remove all the aerators, turn on the water and let it clean the lines then replace the aerators. I think too that the faucets have built in flow restrictors so you don't use as much water since you may be pulling from the potable tanks.
2016 Flagstaff 27VRL Emerald
14K Equalizer
2020 Silverado 2500HD CC 4X4 6.6L gas 3.73
