Originally Posted by bish
Hi we are new to this and have imported a new 8280ws fifth wheel trailer to the uk. I'm having trouble with the water coming through via city link up. Can anyone help!! Is there a valve to switch from fresh water to city link??
Do you mean water filling the storage tank from the city connection?
If so I believe your issue is the valve on the pump. You can try to turn off city water and depressureize by opening the sink. Then close the sink and turn on the pump (assuming water is in the tank because you filled it unintentionally). Let it run about 30 seconds and turn off the faucet and then the pump. Then you can turn city water again.
I would suggest a water regulator if you don't have one. Betting high pressure could have caused the valve problem.
Best of luck and let is know if this worked.
