This is what I use but as stated, find one you like.
Tips, after sides are deployed or retracted, check to insure the wipers have flipped. If not, I use a yardstick or an awning retraction rod to gently slide behind and flip. If not checked, the wipers will take a set and reduce sealing capacity.
Use the conditioner as often as needed because exposer to the sun will age them and stiff wipers in the winter will cause them to crack. I usually spray the outside every quarter and the inside every 6 months.
Remember to condition the inside wipers as well, probably not as often as outside wipers.
2014 Sunseeker 3170 DSF
Dorothy, Garrette and Miss Bella.
Retired and having fun.
