12-05-2020, 05:57 PM
Conditioning and lubrication of slide out seals
I saw something about this today but now I can't find it!! I'd like to know how often and what product is best.
Thanks!
12-05-2020, 06:00 PM
Aerospace 303
12-05-2020, 06:55 PM
Head Rambler
There are plenty of slide seal conditioners and they all work pretty well. Pick the one you like best.
I use 3-In-One rubber seal conditioner, but others are good also. I apply it about every six months.
Gotta go campin!
12-05-2020, 07:19 PM
Seal conditioner
3 in 1 sounds like it is not specific to RV slide-out seals, and as a result, probably not as expensive. Shipping from Camping World was almost as much as a can of RV Seal Conditioner.
Thank you.
12-06-2020, 03:25 PM
3-in-One RV care rubber seal conditioner
3-in-One RV care rubber seal conditioner is available at Walmart cheaper than the rubber seal conditioners at Camping World.
12-06-2020, 03:33 PM
Good to know, and not surprising.
12-06-2020, 05:16 PM
This is what I use but as stated, find one you like.
Tips, after sides are deployed or retracted, check to insure the wipers have flipped. If not, I use a yardstick or an awning retraction rod to gently slide behind and flip. If not checked, the wipers will take a set and reduce sealing capacity.
Use the conditioner as often as needed because exposer to the sun will age them and stiff wipers in the winter will cause them to crack. I usually spray the outside every quarter and the inside every 6 months.
Remember to condition the inside wipers as well, probably not as often as outside wipers.
2014 Sunseeker 3170 DSF
Dorothy, Garrette and Miss Bella.
Retired and having fun.
12-06-2020, 08:00 PM
Originally Posted by bikendan
Aerospace 303
X2 on Aerospace 303, good stuff. It is a little expensive so I bought a gallon on amazon for $56. Use it for many things including seals.
2016 Dynamax Isata 3 24FW
2016 Jeep Willys JK
Yellow Labs Buddy Biscuit Eater, Mr. Jake (RIP), Casey Girl (RIP)
USN-RET/DOD-RET
12-06-2020, 08:49 PM
I use the same product as Garrette recommended from Amazon
https://www.amazon.com/Premium-Slide...7305492&sr=8-2
Sprays on like a foam - I only use it twice a year, once when closing camping for winter and once when opening in the spring.
Good Luck!
Ken & Marie
2017 Heritage Glen 272RL - 34' 4" hitch to bumper (UVW 7294 lbs / hitch 845 lbs)
2016 GMC Sierra 1500SLE 4wd, w/tow pkg, 5.3L-V8, 1726lb payload, 3.42 axle ratio, 9200lb tow weight
I wish I started camping earlier in life
12-06-2020, 09:08 PM
Camping with Labs
X3 for 303. Have used it on all four of our TTs, and on many vehicles as well over the years. And I also buy it by the gallon - great product!!!
Chris, Paula, & camping Labs, Shasta (RIP 8/10/20) & Cammie
2005 Yukon XL 2500 with 8.1 Engine, Allison Transmission, and 3.73 Axle Ratio
2019 Rockwood Signature 8335BSS with Hensley Arrow Hitch
