Old 09-12-2021, 05:20 PM   #1
Crack in fiberglass wall
Just noticed a crack in the exterior wall of our Rockwood Signature. Bought it in March of 2020. Has anybody delt with this? Not sure if the walls have any longer warranty than the standard one year Click image for larger version
Vinny09 is offline   Reply With Quote
Old 09-12-2021, 05:30 PM   #2
Just Tryin' to Help
cboss's Avatar
Where is the crack? Can you give us a wider Pic?
2020....bummer!
Craig & Cath
2017 Ford F250 Lariat, 6.2 gas (2022 F250 Lariat 7.3 gas with 10 speed Xmsn on order)
Equalizer Hitch w/ 4-Point Sway Control
Days camped since 2015(retirement): 1050
cboss is online now   Reply With Quote
Old 09-12-2021, 06:11 PM   #3
It’s at the bottom corner of the bedroom slide opening
Old 09-12-2021, 06:21 PM   #4
Just Tryin' to Help
cboss's Avatar
One of our slides started to separate from the floor. Turned out it was not fastened properly to the floor. It did not create any cracks, but I've always felt it would have it we didn't repair it in time.
As far as a repair, I'd fix the problem that caused it first, then a little fiberglass repair would hopefully fix the issue and cover up the crack.
I wish you the best.
Craig & Cath
Old 09-12-2021, 07:06 PM   #5
Hclarkx's Avatar
Is there anything awry on the other side (inside) in the same area that might give you a hint. Seems worrisome in that some unseen structural members must have shifted to create the tension in the wall that caused the crack. This could be associated with the frame. My Rockwood had a cracked frame just behind the wheels that seems to have been the result of stress from 90 degree jack-knife turn-around maneuvers on narrow roads. I did have some bowing of the wall above that area though I can't say for sure that came from the frame flexing. I've since reinforced the frame.
2020 GMC Denali 2500HD Crew 4X4 Gas 6.6L
2015 30' 8280WS Rockwood Ultra Lite - lifted 3"
Solar plus LiFePO4 and 12V fridge.
Hclarkx is online now   Reply With Quote
Old 09-12-2021, 08:05 PM   #6
Hi, I have a new 2021 Forester MBS 2401B. Bought it last July, 2020 and only 1,200 miles. Have not used it yet because of the problems. Just had second 12 volt fridge put in and new microwave, 1-2-3-5- buttons didn't work. Now dealer just ordered new transfer switch as it only worked when it felt like it. All this after about 8 smaller issues. On top of that, Yesterday just noticed 3 cracks in the exterior, one on each top corner of hot water heater about 4 and 6 inches long, and one on top corner of storage compartment about 6 inches long, all passenger side. Were hard to see because of color but yesterday seems like sun opened one crack up a little making it easy to see. Made me sick. Has never been used just back and forth for repairs. No Forester dealer here in Wisconsin so i bought it in Ohio which is about 600 miles. The other 600 is going back and forth for service here in Wi. all on paved roads. Anyone know what normal procedure for repairing this '' junk'' if I can call it that. Will contact dealer in Ohio tomorrow, thanks for any advice.
gmoose is offline   Reply With Quote
Old 09-12-2021, 09:12 PM   #7
whirledpeaz's Avatar
Just noticed a crack in the exterior wall of our Rockwood Signature. Bought it in March of 2020. Has anybody delt with this? Not sure if the walls have any longer warranty than the standard one year Attachment 262715
What model Rockwood Signature do you have?
2020 Rockwood UltraLite 2608BS
2017 F250
whirledpeaz is offline   Reply With Quote
Old 09-12-2021, 09:27 PM   #8
D W
D W's Avatar
Those frames, structures and tongues are not designed to handle a 90° jackknife, I always exercise the aviation rule: "no more than a 70° push or pull.
2016 Salem 27RKSS
D W is online now   Reply With Quote
Old 09-13-2021, 01:12 AM   #9
Hclarkx's Avatar
This may not be just a simple crack due to a weakness in the fiberglass. It seems likely there's something deeper going on. Getting the dealer to look deeper and find the root cause is worth a try, though probably a lost cause. The dealer will probably camouflage the crack but I'd guess it will come back.
The root cause, if something other than a weakness in the cracked panel, isn't necessarily a major problem, but it could be. I.e., a missing weld or similar.
I'm in the process of repairing the undercarriage in my Signature Ultralite. I found welds that ran along one side of a joint, not touching the other side, thus doing nothing. Some welds were missing altogether. Others were just poor welds that cracked. My problems were aggravated by a considerable amount of off-road use (washboard and similar) over six years, but still, it seems there was no safety margin in the structural design.
Old 09-13-2021, 01:28 AM   #10
Hclarkx's Avatar
I've never heard this and it wasn't in my manual. Also, pulling at 70° instead of 90° only reduces the lateral force by 6%. Surely there's more margin than that!
But, FWIW, I only mentioned the frame problem above, I found undercarriage falling apart at the same time I saw the frame crack. I say "was" because I just spent a few hours under the RV with a MIG welder.
I did let the passenger 5er wheels drop off the pavement on a sweeping left bend in the road about a year ago. The pavement had been chewed away by others doing the same (even the fog line was gone). The wheels had to climb a 6" "curb" at a couple degree angle to get back on the roadway. By the time there was enough force to make this happen, the 5er swung violently across my lane into oncoming traffic. Fortunately it did so between cars and no collision resulted. I'd guess this event contributed to the weld problems (see above) and the crack in the frame more than the few 90° jack knife events. Incidentally, as noted above, the frame crack was behind the wheels so was likely due more to this event than the jack knife events as I indicated.
Old 09-13-2021, 08:58 AM   #11
Thank You
Old 09-13-2021, 12:26 PM   #12
lckeehne's Avatar
Fiberglass Crack
Great question! I have a 2011 Sierra 300RL with the same problem.
I took into repair the crack or at least to stop the crack from getting bigger.
They "CUT" the fiberglass straight down from the corner of the opening for slide. Then put a sleeve on it so that the pressure is removed. Looked pretty simple and good.
THe only problem is that the crack continues to grow even so slightly. So if there is another FIX please let us know.
Thank you, Larry
2011 5thWheel Sierra
F250 Ford 2008 Diesel
Larry & Sharon
lckeehne is offline   Reply With Quote
Old 09-13-2021, 07:03 PM   #13
Can’t tell from the picture if the crack is within the slide or outside. But it seems to me that there is something pushing the wall out at that location. It could be a structural member inside the wall that was damaged during the incident. So I would wonder when the crack appeared in relation to the incident. If it was a short time then perhaps one could make a correlation between the two.
I would look to see what structure is inside the rig near the crack. Maybe there is a cabinet that got tweaked during the incident and the slide is rubbing or pushing on it when extending or retracting it. Just my 2 cents
jincali is offline   Reply With Quote
Old 09-14-2021, 10:07 PM   #14
2020 8288 sb
crack, fiberglass
