Originally Posted by Richard Burkman
All video's I've see were 2 string, not 4 string. The springs, rails and string layout for this are different than others I've seen. I've contacted the manufacturer, United, as was told it is imported and cannot be restrung. For the replacement cost, I'm ok with replacing. I'm just concerned about screwing into what I suppose is the foam wall.
Ok, however mine are four string and easily did mine, but replacing may be easier. Actually, mine were two long strings made to be four strings showing, so maybe yours if actually four? Adjusting the draw strength is the hardest job of all of it and you may want to watch a few videos to help with adjusting to make it go up and down correctly. Still, using th same screw holes should work just fine.
