Old 02-10-2020, 11:34 AM   #1
jdm7's Avatar
Different Stablizing when Seasonal?
We're going to do a seasonal site this year for the first time, to make life a little easier while doing construction at my house.
Looking at other seasonal campers over the years, I would often see trailers on CMU blocks or other setups. Is there a better setup for a longer term stay for less movement on the travel trailer?
I considered placing CMU underneath but I've read here about a couple blowouts, so... maybe not, haha!
I typically just use PT 4x4 blocks and have no problem reaching them with my stabilizer jacks, and combine that with a chock between the dual axle tires - it has some movement but not much - should I just stick with that setup?
2016 F-150
2017 Mini Lite 2509S
jdm7 is offline   Reply With Quote
Old 02-10-2020, 11:49 AM   #2
I've talked to some folks who seasonal camp and they like to add a concrete block, then a stabilizer jack to the frame to keep the jack as short as reasonable.
Most folks I talked to did 8 total, 2 at the front, 2 at the rear, 2 a couple feet in front of the axles and 2 a couple feet behind the axles.
Camco makes lite weight aluminum ones while EZ Lift makes heavy duty steel ones. I think I am going to grab 4 of the lite weight ones for ease of handling and reduced cargo payload. No one I spoke to was unhappy using a simple hand crank trailer stabilizer like this, all I spoke to said that it helps, but no one ever claimed that any amount of insanity with blocks/stabilizers would make it feel dead solid like your real house.
https://www.amazon.com/EAZ-LIFT-4886...S11DEBFMKPB1YC
2017 Ram Rebel 1500 5.7L / 8 Speed, Max Tow 10,160 lb / 1,075 lb payload rating.
2019 F-150 King Ranch 3.5 Eco-Boost 10-speed, 12,800 lb / 1,546 payload.
2020 FR Coachmen Apex Ultra Lite 289TBSS
2019 Quality Trailers 16'x7' 7K GVWR Utility Trailer
2019 Iron Bull 22'x102" 14K GVWR Equipment Trailer
2019 Kawasaki Mule Pro DX W/EPS and Yanmar Diesel 2,000 LB towing and 1,000 payload.
Larry0071 is offline   Reply With Quote
Old 02-10-2020, 11:50 AM   #3
The Camco aluminum ones....
https://www.amazon.com/Camco-Olympia.../dp/B000760FWU
Old 02-10-2020, 11:58 AM   #4
We just stack the blocks up to the frame and then add wood and wood shims to tighten it up. No need for a stabilizer jack.
Iwritecode is offline   Reply With Quote
Old 02-10-2020, 04:31 PM   #5
X2
Cedar Creek Lake, Texas
2019 Keystone Loredo 290SRL
Andersen hitch
CedarCreekWoody is offline   Reply With Quote
Old 02-10-2020, 05:08 PM   #6
I place planks under the wheels to prevent them from sinking into the ground. I then stack solid concrete blocks up to a couple of inches from the leveling jacks. I will drop the tongue 3-4" down from level and set the rear jacks. I run the tongue slightly above level and set the front jacks. Run the tongue back down to place the weight on the front leveling jacks. This removes most of the bounce from the trailer.
Catalina 333RETS
Keystone Outback 23RS
Silverado 2500HD
Goldwing 1800GL
Wilco is offline   Reply With Quote
Old 02-10-2020, 05:10 PM   #7
Get (4) of the 3 Ton automotive jack stands from Harbor Freight. About $20 pair.
2019 Sunseeker 3010DS
160w/9A roof top SOLAR
Playmaker DISH w/ Wally
Blank is offline   Reply With Quote
Old 02-10-2020, 06:04 PM   #8
walleyewizard's Avatar
It is much stronger to stack blocks with cells facing up and down
2017 Crusader Lite 29RS 5er 2018 Silverado 1500 5.3
walleyewizard is offline   Reply With Quote
Old 02-10-2020, 06:12 PM   #9
Correct wallywizard.
Technically, structural engineers are taught that turned the wrong way as above, they have 0 strength. I have seen single blocks fail as a trailer tongue block.
tomkatb is offline   Reply With Quote
Old 02-10-2020, 06:37 PM   #10
cavie's Avatar
Name:	What he said in that comment up there (1).jpg
2011 Keystone Sprinter 323BHS
Port Charlotte Fl/Hinsdale Ma
Retired Master Electrician.
Old 02-11-2020, 06:40 AM   #11
bareftn's Avatar
years ago working with a person who sets up mobile homes The concrete blacks are on the side the strength is to place then with the holes up and down
bareftn is offline   Reply With Quote
Old 02-11-2020, 06:51 AM   #12
In his defense.... He is not asking for any strength at all from his improperly used blocks. He is asking them to stop deflection of the frame/suspension with just a few pounds of force being applied. And he is a computer programmer, so it's not as if he is expected to be versed in the proper use of construction materials :-) I bet a lot of men do not know the strong orientation of a block, not just him.
Old 02-11-2020, 07:16 AM   #13
cavie's Avatar
Old 02-11-2020, 07:21 AM   #14
bareftn's Avatar
I am letting other s know they are placed wrong I see it so many times
Old 02-11-2020, 08:15 AM   #15
Post number 8 explained that LOL.
Old 02-11-2020, 10:21 AM   #16
I use 2 of these under the rear end frame on my Crusader. Really helps the bounce and wiggle. My wife likes to sleep in so she really likes them as I am an early riser, and the dog needs to go out, etc. I don't do much else beyond the auto-leveling system. Blocking up under the front jacks might help as some say, I just don't like carrying a bunch of blocks around.
2003 Duramax
2017 Crusader 315
2016 Boston Whaler Montauk 150
Former Montana owner
Colorado Cruiser, Over the Pass and Down the Hill
Comanchecreek is offline   Reply With Quote
Old 02-11-2020, 10:22 AM   #17
I've posted that pic before and this exact same discussion took place.
Basically, you are correct in that I'm not looking for the blocks to hold a ton of weight. They essentially aren't much more than stabilizers.
But I put them with the holes on the side on purpose because I want the most surface area on the ground so they don't sink as much. And they do tend to sink a little after a few years.
It's also easier to put the wood shims in on the flat surface instead of the side with the holes. In this picture I have an extra half-block on there and another piece of wood but sometimes the blocks fit perfectly under the trailer and you just need a single shim. Trying to get it on the small area where it's actually contacting the frame would be a PITA.
Also in my defense, the first time I learned this trick was when we had our first TT delivered to our seasonal site. The guy that delivered them also set them up and put the blocks down for us. He has years of experience and he put them flat side down as well.
Old 02-11-2020, 10:35 AM   #18
Agreed... no harm in what you did.
Also agree the strength in the block is the other way but you are not trying to hold up the weight of the R/V nor a two story building so placing them as you have is perfectly fine and they DO provide more surface area in that position.
Now... if you were removing the wheels/tires and expecting the blocks to support the ENTIRE weight of the R/V, then that is a horse of a different color.
For simply STABILIZING... they will do the job just fine as they are.
It is good to see though there are now "cement block police" looking out for those of us on this forum.
Days Camped: '17=30 '18=51 '19=58 '20=41
Old 02-11-2020, 11:21 AM   #19
NMWildcat's Avatar
Maybe you could have the best of both worlds. Buy the concrete cap blocks that are the same size as the concrete block, but 2" or 4" thick. Put the flat caps on the ground and the top of the stack, and place your concrete blocks holes up to use their strength. And there it is!
https://www.homedepot.com/p/2-in-x-8...N1AN/206125462
Scott and Liz - Southern NM
Old 02-11-2020, 11:24 AM   #20
The next time any of the blocks crack will be the first time. I'm not too worried about it.
