09-22-2017, 02:08 PM
Digital TV
I just bought a new Windjammer. We have taken 3 trips in it and I cannot figure out how to get digital tv channels to come in.
I turn on the amplifier and the green light comes on. I also run a cable from the outlet by the power switch to he tv. Then I set the tv source to antenna and scan for channels. It does not find any.
I’ve been just north of Denton, just west of Tyler, and just outside of Georgetown; all in Texas. All these locations should be close enough to metropolitan areas where digital channels would be available.
Just wondering if I am doing something wrong. Any suggestions?
09-22-2017, 02:13 PM
The light on the amplifier should be off if connected to cable or satellite. The amplifier is for antenna use only.
09-22-2017, 02:15 PM
I see I misread your post. Shouldn't be a need to run a cable for local.
09-22-2017, 02:16 PM
Sounds like you are using the right process.
Next would be to remove the wall plate and start checking connections.
Under warranty?
Days Camped ☼ '19=118 ☼ '20=116 ☼ '21=123 ☼ '22=134 ☼ '23=118☼ '24=64
09-22-2017, 02:18 PM
Under warranty?
Yes, it is brand new.
09-22-2017, 02:25 PM
Some TVs had separate options to digital and analog tuning. Did you check this?
I have no idea how strong of signal you have in those areas but unlike the old days where you could at least get a poor picture, with digital it is good or nothing.
if your switch plate has 2 outlets try both in case they are mis-labeled or mis-wired
Almost not an SOB
Artic Fox 3018 5th Wheel - on order
Grand Design 2800BH TT 2021
Prior TT 2017 Flagstaff 831CLBSS Classic Ultra lite - SOLD 5/21
TV 2024 F350 DRW - on order
TV 2017 F150 6.5' bed 3.5 Eco-boost Max tow 1800lbs payload
09-22-2017, 02:28 PM
Kanadian Kamper
In my rig....there’s also a selector switch to choose antennae, park cable (connected with coax into one of my cargo bays) or satellite (if you have one)
The green booster light should ONLY be on for antennae.
If the TV was factory install.....it should have coax connector on the back already...no need to run coax from TV to connector beside the booster button.
Ken and Terry
09-22-2017, 09:01 PM
This may be of some help to you.
2011 Traverse LT, 3.6L, FWD
09-23-2017, 11:50 AM
Newbie
Have you fully raised your antenna?
How 'bout them Cowboys!
2015 Rockwood 2104S
2013 F150 4x4 EcoPuller
09-23-2017, 11:52 AM
It doesn’t raise...just turns.
09-23-2017, 12:23 PM
I found that turning on the surround sound helps with the signal reception.
09-23-2017, 04:58 PM
Someone is going to have to explain that one to me??
09-24-2017, 07:35 AM
Don't know why but I was in a rural area with poor reception if someone went into the bathroom picture would become sort of scrambled. When the power was turned on to the DVD/radio the picture stayed and there were more channels available.
