10-30-2020, 10:14 PM
Do I have electric heat?
Just bought a Rockwood 8335sb and don't remember what the dealer said. Is it wired for electric heat or if it HAS electric heat.
Anyone?
10-30-2020, 11:09 PM
Unless it has a heat pump, which I doubt, just a propane furnace.
10-30-2020, 11:15 PM
It's possible that you have a heat strip on your air conditioner, but that doesn't put out much heat. As bikendan said, it's probably just your propane heater.
If you have electricity, many of us buy a space heater to warm up our rigs rather than paying for propane. We have one that has a thermostat built in to control the heat and we've got one that's cool to the touch to protect the clutz in the household.
2015 Dynamax REV 24TB class C
10-31-2020, 12:03 AM
We do too...just wondering since the thermostat gave the option
10-31-2020, 06:19 AM
Electruc fireplace?
2021 Flagstaff 26FKBS (manuf. 3/20/2020)
2019 Ford F150 XLT-3.5EB, Ext Cab, 3.55, Max Tow, 1,910# Payload, Blue Ox 1500
2018-12 days/2019-83 days/2020-12
10-31-2020, 09:40 AM
No. Electric heat through ceiling unit
Originally Posted by TRD
Electruc fireplace?
10-31-2020, 11:54 AM
They have been putting a heat strip in the bedroom a/c unit. I think it is around 5000 BTU.
2020 Rockwood Signature 8332SB
2005 E-350 with V-10
10-31-2020, 02:01 PM
Just a note for the OP that if your heat is from Propane...the fan that blows it is electric and a good sized battery drain if you're not plugged in somewhere.
________
Cam
2015 Georgetown 280DS
10-31-2020, 02:07 PM
"the fan that blows it is electric and a good-sized battery drain if you're not plugged in somewhere" and the heater really likes propane.
10-31-2020, 04:28 PM
I have a mini lite 2506s, and just use the fireplace with the fan on continuous.
Been camping in temps down to 28 and just fine inside.
11-01-2020, 07:38 AM
2018 Rockwood 8324BS
I added a heat strip to the living area AC unit just like the one in the bedroom - bought the heat strip and a relay and wired it up like the wiring diagram shows - but be sure that your thermostat has heat for that zone as an option.
Boyd
Lake Charles, LA
2020 F250 Diesel
11-01-2020, 09:59 AM
We carry a small Ele Heater, does a very good job, and uses no propane !!!
11-01-2020, 08:25 PM
I carry a ceramic heater that I use when we are plugged into shore power. If it gets really cold (like 10 degrees) my furnace will come on when the electric can't do it alone. If it is that cold, we dry camp because we don't have tank heaters.
11-02-2020, 02:13 AM
I also bought a signature 5th wheel. I also have the same question. When I turn on electric heat on the thermostat. The unit heats though the A/C vents. It works on the first cycle and heats, shuts off after it hits the set temp. Then it blows cold when on the next cycle and won't heat up. I have to switch to gas to heat up the 5vr.
Looking for answers...
