09-25-2020, 06:17 PM
Dometic 2 door 3 way fridge not cooling...
Dometic 2 door 3 way fridge not cooling in the fridge, but the freezer works just fine... 120v power no problem.
is there a 'cavity' or connection between the two areas that could be clogged?
or
how does the 'thermistor' temp sensor work? What does it tell the fridge to 'do'?
The Turners...
09-25-2020, 07:00 PM
or
Are you sure it's a 3-way fridge because Rockwood only puts 3-way fridges in the popups and A-frame trailers. And your trailer is neither one of those.
What brand and model number is it.
09-26-2020, 09:08 AM
sorry, it's a two-way, with constant 120v power - and the freezer works perfectly, but no matter when the 'thermistor' sensor height is on the fridge section, it's not cooling now, even though it has been for months.
09-26-2020, 10:48 AM
Just as confused as you
Since you have been having problems with your RM-2652 refrigerator for quite some time, (reference this thread: https://www.forestriverforums.com/fo...er-210854.html), have you disconnected all the terminals and reinstalled them? If there is oxidation on the pins and connections doing this can reestablish a good connection.
Other than that maybe it's time to break down and buy a new control board and possibly a new thermistor. Dinosaur Boards Dinosaur Electronics Home. High quality circuit boards for RV appliances. make great replacement boards. They have a cross reference chart where you need the number on the board or a list by fridge model number. https://www.dinosaurelectronics.com/Dom_Chart.htm
Have you followed the troubleshooting procedures in the service manual I sent you back on 7/12 in post #26?
Richard & Jill
09-26-2020, 04:34 PM
Originally Posted by Scrapper
I had the same problem you’re having with my Rockwood. It was at the dealer 3 times and they couldn’t figure it out. Twice we had to throw out all the food in it because they thought they fixed it. Finally i figured it out. I noticed that the flap on the left door wasn’t flipping to seal the doors and there was a 1/2” gap that let the cold air pour out. It still took 2 more dealer visits to get it adjusted right.
09-27-2020, 08:30 AM
SOLVED! ...
o.k., we've solved the recent problem...
history: bought the used RV back in June, fridge and freezer worked perfectly all that time since
recent: fridge lost cooling, freezer seemed to be working just fine
SOLUTION: I realized that recently while 'winterizing' much of the RV, and having put insulation batts behind each outside compartment door, I had also had the 'brilliant' idea of also putting insulation batts behind the fridge's outside vent cover.
I now realize that this is a mistake, as RV fridge's need air flow...
when we removed the insulation yesterday, the fridge today is suddenly COOLING just as it should be....solved.
The Turners...
09-27-2020, 08:53 AM
Thanks for letting us know what you did wrong to cause your problem and what needed to be done to fix it.
I know you had been having problems with this fridge back in July and I sent you a couple of owners manuals along with the service manual for your specific model. https://www.forestriverforums.com/fo...er-210854.html
In the manuals it says not to block the vents in any way.
It seems you have another problem, reading and understanding information others give you.
I'm done.....
Richard & Jill
09-27-2020, 09:10 AM
yes, I certainly accept the blame here... I think my 'reasoning' for adding the insulation was from the other RV we own, my son's camper, which we replaced the small RV fridge with a much larger apartment fridge - 120v only, and no longer needed the outside vent. I insulated his the same, and apparently thought that since this other RV fridge was 'only' using 120v power all the time, insulation behind it wouldn't matter, either. Wrong. : /
The Turners...
