Old 04-07-2011, 04:35 PM   #1
Nights Camped in 2010 - 2
Drain hose on reefer
All,
Hello. I am getting the TT ready for an outting this weekend and was checking the Reefer Compartment to make sure no critters wintered over in there. As I was looking around, I saw a kinck in the hose about 1/4 of the way up into the compartment. Is this right? Also, is is hard to pulll the reefer to fix the hose? I have the basic model Dometic (?)(Fridge/Freezer). I was surprised to see the kinck because that is how it came from the factor. Thanks,
George Kelly
2011 Rockwood Ultra Light 2604
Dodge RAM 1500 Larime 4x4, 5.7 HEMI
Nights Camped 2010 = 18
Nights Camped 2011 = 15
sailingsuppo46 is offline   Reply With Quote
Old 04-07-2011, 04:43 PM   #2
Dave_Monica's Avatar
Unless the drainage hose is cracked and leaking where it's kinked, I wouldn't bother changing it...especially if the fridge has to be removed. It's only job is to drain water from the fridge's tray under the freezer when defrosting.
Dave
Old 04-07-2011, 09:58 PM   #3
Dave,
Thanks. I straighten the hose and then poured some water through the drain in the reefer. No leaks, so I am going to let it go as is for now. I have a bigger problem. The slide is shorting out something when its fully extended and blowing the fuse for the living area. I have to pull the closers off the bottom and troubleshoot in the morning. Hopefully, will not take long and I can still go camping. If not, its home for the weekend, working on the trailer. Thanks,
George Kelly
