Old 02-08-2020, 11:26 PM   #1
Electric Stabilizer Jacks?
Anyone have have experience with the electric stabilizer jacks? Any problems?
thanks
flyflotrtim is offline   Reply With Quote
Old 02-09-2020, 12:26 AM   #2
dbledan's Avatar
Had mine for 3 years now.
The only issue I have had is when I blew the DC breaker when I tried to do both at the same time. Reset and no issues. They blow the breaker if you try to keep cranking them after they hit their limit. They did that during my PDI...CW what are you going to do. At least I found out which breaker it was then.
I am careful to not push them too far when raising them and putting weight on them. They were not built to lift the trailer, just hold it.
dbledan is offline   Reply With Quote
Old 02-09-2020, 08:10 AM   #3
Head Rambler
There is a lot of experience with electric stabilizers around here. Some good and some bad.
We've never had problems with ours. One thing to do to prevent problems as much as possible is to keep them lubed with a good dry lube.
Gotta go campin!
Old 02-09-2020, 11:23 AM   #4
Didn't care if I got them or not until I used them on the new trailer. They are so quick and easy, really like them, hopefully they'll be reliable.
2020 Rockwood 2104s towed by 2018 Nissan Armada. Curt WDH with sway, portable 100 watt solar, Home made window evaporative cooler
trailerdude is offline   Reply With Quote
Old 02-09-2020, 11:37 AM   #5
Explore
Camp4two's Avatar
Been using them for 1.5 years and no issues. Use them as intended...to stabilize NOT lift. Keep them dry lubed. I will never go back to manual crank stabilizer jacks.
2511S/25FBLS Quick Reference Guide at Post #300, FR Rockwood Travel Trailer Forum, Mini Lite 2511S Owners Thread
2019.5 Rockwood Mini Lite 2511S
2014 F150 Lariat 4x4 3.5 EB
Camp4two is offline   Reply With Quote
Old 02-09-2020, 11:50 AM   #6
X2.
Use them for what they are intended, (stabilizing) and they'll last a long time and are quick and easy.
Ours have worked flawlessly on our most recent 5th wheel (rear) for over 3 years.
Days Camped: '17=30 '18=51 '19=58 '20=41
Old 02-09-2020, 01:04 PM   #7
SeaDog's Avatar
X2.
X2 they are stabilizers not jacks for lifting.
Retired Navy
Jake my sidekick (yellow Lab)
2016 Flagstaff 26 FKWS
Old 02-09-2020, 05:57 PM   #8
Thanks everyone, sounds like the electric stabilizers are a solid investment.
electric, jacks, stabilizer
