Old 03-27-2017, 02:04 PM   #1
Found part
Found this part on floor after putting slide out
Rockwood 2109s anyone recognize this?
ID:	133048 has a Allen set screw.
2017 Rockwood Minilite 2109S
2017 GMC 2500HD gasser
Markval is offline   Reply With Quote
Old 03-27-2017, 02:09 PM   #2
I would guess that it is some sort of a stop or guide for the slide. That is a set screw in it, isn't it. Try looking up a diagram of your slide mechanism and look for it that way.
Bob
2013 Ford F250 SD 6.7L
2014 Wildwood Heritage Glen 282RK
Certified Rumble Strip Tester
retiredcamper47 is offline   Reply With Quote
Old 03-27-2017, 02:16 PM   #3
Bob
Thanks Bob
Old 03-28-2017, 03:00 PM   #4
Attachment 133048 has a Allen set screw.
Bump
Old 03-28-2017, 03:10 PM   #5
I have no idea what it might have been for in your camper but they sell those exact same lock stops for sticks and bricks houses as an anti-theft device to keep the sliding doors/windows from opening. Slide it down over the track and tighten the set screw.
Maybe a travel lock for the slider for the ride from the factory?
To be removed by the dealer?
To be used in an emergency to keep the slide closed in case of gear/motor failure?
I've never heard or seen of such but stranger things can happen.
Days Camped: '17=30 '18=51 '19=58 '20=55
Old 03-29-2017, 10:12 PM   #6
RangeMaggotBob's Avatar
Yes, it's part of your slide-out mechanism, and you need to get somebody to look at it and repair it ASAP!
2015 Forest River Rockwood Signature Series Ultra Lite 8289WS w/Diamond pkg.
2014 RAM CTD 6.7 Tradesman 4WD Auto Crew Cab Long Bed
Honda eu2000i generators
RangeMaggotBob is offline   Reply With Quote
Old 03-30-2017, 04:53 AM   #7
You seem to have knowledge of this piece. What does it do and where on the slide is it located?
Old 03-30-2017, 05:59 AM   #8
Its a stop block for a LCI above floor / sofa slide. It limits the slides outward and inward travel and gets clamped on the edge of the rack / hat channel that is mounted underneath. If you pull the lower front panel off the sofa you may be able to see the marks from the set screw on the edge of the rack where it was originally installed.
Mr Havercamp is offline   Reply With Quote
Old 03-30-2017, 06:08 AM   #9
Thanks!
Old 03-30-2017, 10:29 AM   #10
Thanks will advise.
Old 03-30-2017, 09:50 PM   #11
See last 2 posts above. Looks like Mr. Havercamp has you covered!
Old 03-31-2017, 04:30 PM   #12
Found part
I can report that the slide acted funny when we retracted it. It did come in and we were able to get it home
Old 04-01-2017, 09:16 PM   #13
Went searching for rail if under couch can't figure a way to access it.
Old 04-02-2017, 02:29 PM   #14
Found part
Well as it turns out front of couch is held on with Velcro. Found location of stop and is now in place. thanks for the helpClick image for larger version
Old 04-02-2017, 02:32 PM   #15
crunchman12001's Avatar
Excellent. Thank you for the follow up. Glad you got it fixed.
2015 F-250 FX4
Old 09-07-2017, 12:36 PM   #16
Jezzz we found another random part under the couch today at ideas?Click image for larger version
Old 09-07-2017, 12:45 PM   #17
wmtire's Avatar
Jezzz we found another random part under the couch today at ideas?Attachment 150869
Just a guess, but it looks like an adjustable leveler of some kind. Maybe to the couch leg or something.
2011 Flagstaff 831 RLBSS
Geaux Tigers!!!!
Old 09-07-2017, 12:47 PM   #18
That was my first thought but nothing to match on couch.
Old 09-07-2017, 12:54 PM   #19
wmtire's Avatar
Does the couch fold out into a bed?
Geaux Tigers!!!!
Old 09-07-2017, 01:05 PM   #20
Jack knife bed great thought I'll have to go searching that next.
