Originally Posted by lamokadave
Many thanks Atrider. This might be as close to a direct comparison that I'd ever see.
Where is your fresh water tank relative to the trailer axles. We frequently boondock so will likely need to carry water weight occasionally.
Would hope not to add that to the tongue
Looking at pics of a 2507 on line, it appears that the black and grey tanks are behind the axle, just like on my 2503S. So the FW tank will either be between or in front of the axles.
On my 2503S the FW tank is above the axles (drain is right between them). I piped it out to the side so I could drain without crawling underneath.
In the pic, you can see the gray tank just behind the wheels. The black tank is behind the grey. (Rear of trailer is to the right.)
2011 Traverse LT, 3.6L, FWD
