08-06-2017, 07:57 PM
Fresh water pump
So we set up at campground today and have to use FW Tank because there is no water hook up here. I have used the pump this year without any problems but today it wouldn't work. Turn the pump on and it just runs and no water comes out of any faucets. I have a full tank of fresh water, valve for winterization is good but nothing, no leaks anywhere and from any connections I can see all seems good. Sounds like the pump is humming and not chugging away as usual . No air puffing or any water spitting, not a drop from any faucet or from the toilet. So at this point it is showers in the public place, water holding cans for toilet and another for washing hands throughout the day. Water bottles for coffee and such. It could be worse, I could be at work right? Oh well, just 4 days like this. Heck I use to tent camp so this is a cake walk. Ok it's aggravating as hell but we will survive.
05 Ram 3500 Cummins Dually
14 8280WS Rockwood Sig. Ultra Lite
Prodigy 3 brake Controller
TST 507 TPMS
2017 = 30 nights / 2018 = 7 nights
08-06-2017, 08:20 PM
Sounds like the pump is not priming. 1. Are you sure there is water in the tank? 2. If yes, try opening the pump at the filter glass and put water into the hose in an attempt to prime the pump.
Sent from my Pixel using Forest River Forums mobile app
David Cournoyer
2015 F250 SRW 4x4 Crew Cab Platinum
6.7L Powerstroke V-8 Diesel
2013 Rockwood Windjammer 3001w Diamond
08-06-2017, 09:06 PM
Are you sure the antifreeze valve is set correctly? Just for kicks, move it to the other position.
2011 Traverse LT, 3.6L, FWD
08-07-2017, 07:40 AM
Absolutely yes about water in tank and yes the antifreeze valve is set correctly. The pump was working great for a 4 day trip boondocking last month. I double and triple checked the antifreeze valve trying to figure it out yesterday. I will attempt what handydc suggested since I didn't prime the pump but I'm thinking the pump might be fried.
Thanks for the suggestions, hopefully it works. I will keep you posted.
TST 507 TPMS
08-07-2017, 07:45 AM
You're sure the pump motor is running right?
Did you open a faucet and just let the pump run for several minutes??
I once had a baulky pump that would be stubborn to prime the first time
each trip.
Opening a faucet with the pump running always worked but sometimes it
could take a minute or more.
Once it primed it would be fine the rest of the trip.
As a last resort try loosening the line going to the pump inlet and
pour a dribble of water into the line while the pump is running.
As soon as it takes up that water shut off the pump and reconnect the
line and try again- with a faucet open.
Please let us know what happens!
Peace!
Dan & Rita D
08-07-2017, 07:54 AM
Phat Phrog Stunt Crew
Try opening the antifreeze valve with the siphon hose in a gallon of water. If it primes up the turn the valve to FW line.
2014 Wildcat 327ck
08-07-2017, 11:04 AM
Tried a few more things but nothing. I disconnected the hose and placed my hand over pump and felt suction. I ran pump with faucet(s) open and still nothing. I tried to prime it as suggested by others with no results. I'm stumped.
TST 507 TPMS
08-07-2017, 12:24 PM
If you felt suction at the pump it sure sounds like it's getting air somewhere.
Are you absolutely sure the fresh tank has water??
Positive the antifreeze line is off and capped!!
It sure sounds like it's sucking air.
Where is that coming from???
Peace!
Dan & Rita D
08-07-2017, 12:34 PM
If you had an air leak, you wouldn't feel any suction when you put your hand over the pump inlet. If the suction is there, then it's the water that's NOT there for some reason.
08-07-2017, 02:12 PM
130% certain there is water in tank. 130% antifreeze line is off. Also used pump on boondocking trip last month without any issues. This is kicking my &$$ trying to figure it out. Not letting it ruin my trip now. I am still using toilet and filling bowl with fresh water from water containers. If it's yellow we let it mellow. Showers and any dishes at bathhouse which has a nice setup for dishes.
TST 507 TPMS
08-07-2017, 03:48 PM
I had the same problem the last time I use the fresh water tank. I had drained my tank and lost the water in the line. It took a while but it finally primed up.
Did you try to suck water through the winterization tube like you would be adding anti-freeze to your system? If water is sucked up from that point then you have a blockage from the tank or an air leak in the line. If it doesn't draw water from the winterization tube check the strainer next to the pump for debris in it.
2014 Wildcat 327ck
08-07-2017, 04:00 PM
One quick thing to check... if you unit has a clear suction strainer that screws into the pump inlet... make sure it hasn't vibrated loose. I had a camper that kicked my butt and I found the suction strainer had unscrewed enough (from the vibration of the pump) to where it sucked air. Tightened it and the line that screws into the suction strainer and all was good. Just a thought.
Have you tried switching the antifreeze valve to suck from the antifreeze port, then connecting a short hose to the antifreeze inlet, pouring it full of water, hold higher than the inlet to allow the water to gravity feed down into the pump to prime it?
08-08-2017, 08:29 PM
Well after giving up on water pump yesterday 2 minutes ago I hit the water pump switch for the heck of it for the hundredth time and bam it works now. Very strange but I'm happy
TST 507 TPMS
08-08-2017, 08:33 PM
It just wanted to prime on its own terms
David Cournoyer
08-08-2017, 08:58 PM
Crazy it took since Sunday to prime on its own. Very strange but I'm a happy camper now. Thanks to everyone for there suggestions on a solution.
TST 507 TPMS
08-09-2017, 05:53 AM
I had not used the pump for more than a year (mostly use full-hook up). It wouldn't prime. Hooked a hose to the anitfreeze line and primed it that way. Worked great all week-end.
