11-01-2017, 07:41 AM
Front Window and Cover
Hello!
I recently bought a 2909WS and this is the first TT that we have that have a front window.
I have an ADCO Designer cover and I was wondering if the cover, rubbing on that window, would not damage/scratch it....
Have you had experience with this?
What material that window is made of?
Thank you!
2018 F150 XLT V8 HDPP
2018 Rockwood 2909WS
" Life is simpler when you plow around the stump..."
11-01-2017, 04:08 PM
Can you post a picture? Jay
11-02-2017, 06:52 AM
Here is a picture of my rig.
I don't have a picture of the TT with the cover yet but on the cover there is an external strap that crosses right in the middle of this front window
11-02-2017, 06:59 AM
Is window Tempered Glass ? or a Lexan ?
11-02-2017, 07:01 AM
This is what I don't know!
If it's tempered glass it will be ok but if it's lexan I may have a problem....
11-02-2017, 07:13 AM
Lexan is pretty tough and they do make a polish to remove fine scratches. We have some equipment with large areas of Lexan on them and the polish does an amazing job on it. FR or the dealer may know for sure what the window is.
11-02-2017, 07:19 AM
Have you looked closely around the edges...inside and out ? Seems most tempered windows will have a small stamp somewhere stating "Tempered Glass" The glass shelves in my home refig even have that on them.
Here is some information on the new front windows.
2015 Ram 2500 CTD,CC,SB,4x4
2016 Rockwood 2703 Emerald Edition
Husky CenterLine TS Hitch
TST 507 TPMS
Progressive Industries EMS-PT30X
11-02-2017, 07:20 AM
not tempered glass but windshield glass, which is glass on the outside and plastic inside. It will hold up better then the body
Almost not an SOB
Artic Fox 3018 5th Wheel - on order
Grand Design 2800BH TT 2021
Prior TT 2017 Flagstaff 831CLBSS Classic Ultra lite - SOLD 5/21
TV 2024 F350 DRW - on order
TV 2017 F150 6.5' bed 3.5 Eco-boost Max tow 1800lbs payload
11-02-2017, 07:22 AM
Aaaaah ! Laminated !
11-02-2017, 07:43 AM
Originally Posted by RACarvalho
Hello!
Thank you!
Treat it the same as your TV windshield! Youroo!!
11-02-2017, 08:39 AM
Laminated glass, Great!
So I think it will not get damaged by the cover.
I had lexan on my boats and even though its stronger than other plastic options, it would eventually get faded if a cover keep rubbing on it for months.
Thank you!
11-02-2017, 11:22 AM
Just as confused as you
Isn't windshield glass two layers of tempered glass with a sheet of plastic laminated between them?
Lexan is strong enough that it will stop some bullets. Used 1/4 inch lexan for windows on the shredder control tower. Some chunks were larger than your fist. Some various sized chunks of steel and iron would hit it hard enough it would make you jump. The lexan lasted for about 5 to 10 years before the stress cracks would make it hard to see through when the sun light hit it just right. The cracks never went all the way through the lexan.
Richard & Jill
11-02-2017, 11:27 AM
no, not tempered
Almost not an SOB
11-03-2017, 12:42 PM
Side note.... nascar uses lexan ( for weight reduction) but they have to change them regularly because of abrasions
