Old 10-23-2020, 05:09 PM   #1
Front Window Rock Protection
ID:	241767Click image for larger version
ID:	241768Click image for larger version
ID:	241769Click image for larger version
Lately I have read too many stories of broken front windows caused by rocks. We did this today. We have not taken a trip yet, November 16, 2020 will test it out. We used 3/4” installation board rather than 1/2” in pic. listing price. Just want to pass it on, total cost ran about $43.00. Much better than a $500.00 deductible with insurance co.
Sharon.72064 is offline   Reply With Quote
Old 10-23-2020, 05:14 PM   #2
Looks good. Just keep an eye on it because if wind gets under it, you might loose it. If it survives the first trip, you should be good to go at protecting that window.
2015 Dynamax REV 24TB class C
Reverse_snowbird is offline   Reply With Quote
Old 10-23-2020, 05:28 PM   #3
Just Tryin' to Help
cboss's Avatar
I like your idea. We have 22K+ on our 2902WS. Have had no rock, chip, tar, etc. problems.
Only issue with the front window has been a water leak. Caught it soon enough to avoid any damage. A little Pro Flex Crystal Clear RV Flexible Sealant fixed that.
Thanks for your post!
Craig & Cath
2018 2902WS Rockwood Ultra Lite
2017 Ford F250 Lariat, 6.2 gas
Equalizer Hitch w/ 4-Point Sway Control
Days camped since 2016(retirement): 870
cboss is offline   Reply With Quote
Old 10-28-2020, 03:57 PM   #4
2018 rockwood 2703 front window leaks also. Replaced with new front window still leakks.
JoeyL is offline   Reply With Quote
Old 10-29-2020, 07:07 AM   #5
Just Tryin' to Help
cboss's Avatar
Originally Posted by JoeyL View Post
2018 rockwood 2703 front window leaks also. Replaced with new front window still leaks.
Try the ProFlex. Use the clear and you can't even see it. I put it all around in the gap. No leaks and it's been a year.
Craig & Cath
Old 10-29-2020, 02:48 PM   #6
Is your window centered in the gaps? Mine is not centered sits low with big gap on top. No gap on bottom.
Old 10-29-2020, 03:12 PM   #7
Can't understand why the manufacturer's did away with the old front winder Stone Shield/Awnings.
My old Terry had a fiberglass shield that hinged up when parked and down to take the beating from flying rocks. Also doubled as a sun awning which really helped during hot summer months.
Apparently they weren't "stylish enough
"A wise man can change his mind. A fool never will."
2004 Nissan Titan
TitanMike is offline   Reply With Quote
Old 10-29-2020, 03:39 PM   #8
llr
OP, is that tempered safety glass? Or laminated windshield glass?
The only laminated ones I have seen are slightly curved and mad like a car windshield and don't really need the extra protection.
If yours is tempered I don't understand why it didn't have a factory cover.
TT 2017 Flagstaff 831CLBSS Classic Ultra lite
TV 2017 F150 6.5' bed 3.5 Eco-boost
prior TV 2014 Silverado 2500 HD
llr is offline   Reply With Quote
Old 10-29-2020, 07:12 PM   #9
dbledan's Avatar
Mine has no factory cover and is identical. A cover or lamenated glass is required in some states when sold but not all so I guess they just got into cost savings.
I looked for a cover and could not find one. This seems like it should work well thanks for sharing the idea. I tinted mine darker essentially laminating it on the inside but this would keep rocks off the outside.
dbledan is offline   Reply With Quote
Old 10-30-2020, 06:56 AM   #10
Just Tryin' to Help
cboss's Avatar
Ours is centered. I was able to put the ProFlex all around.
Craig & Cath
window
