Over the last six years I have spent a few weeks each month in my 8281SS 5r for work. The AC is too undersized for the hot CA desert months but I have a portable AC that I use during the day to keep things under control. Some screws have been replaced and all the appliances still work fine. I replaced the internals of the toilet this last winter for a fraction of the cost of a new one, which took about 25 mins start to finish.
I hit some debris on the highway in heavy traffic which caused a blow out a few miles down the road and took out a fender, which I am replacing this spring. All four tires have been replaced. I replaced a propane hose and regulator, a screen door handle, the rivets in the outside step were replaced with bolts. The fantastic vent motor went bad and was replaced (look for a 17 RPM motor rather than the easier to find 7 RPM if you can) and a two of the plastic vents cracked and were replaced. The water heater element switch rusted out and would not stay on, so I replaced it. The fridge does not work on gas probably because the gas regulator went bad, on my list for the spring.
The front room slide motor/gear retention bolt came off while towing (I still have it) and during spring maintenance I will remove the bottom of the rig and fix it. I am getting ready to recoat the roof and redo all the beads. The front door lower hinge needs replacement as it locked up and is disconnected from the door.
It may seem like a lot, but most are little things and like is mentioned above, the Ultralights need a little more TLC if you spend a lot of time in them. Considering the demanding and extreme environment I'm in, I think it is doing pretty well.
2012 Rockwood 8281SS
2012 F-250 6.2 V8
