Originally Posted by RackDaddy
We have a 2020 GeoPro with an inverter. It's located in the "closet" (or ward, under the TV) behind a removable panel. There is also a remote ON/OFF switch above the heater outlet (at the side of the bed).
Obviously, your floor plan is different, but I'd check in the closet/ward to see if there is a panel there.
I’ve checked everywhere and could not find it so I unscrewed the solar panel control box and discovered that there is no wire in the slot that would normally control the inverter. Conclusion: I don’t have one!
Next question, how complicated is-it to retrofit one?
