Old 11-10-2018, 01:52 PM   #21
Here are the pictures of my setup for my 3 12 volt batteries. Right now there are 2 6volts in there. It makes removing the propane tank cover a PITA but I usually only have to do it once a year. NJKris, the key is how much room you will have between the camper box and the propane tanks. Jay
Jay2504 is offline   Reply With Quote
Old 11-11-2018, 01:32 PM   #22
Trailer Park Supervisor
NJKris's Avatar
Battery box sandwich!
Voilá! Like the old Midas commercial..."We'll MAKE it fit!" I think this will do the trick. The board was ripped to what I hope is correct width to fit inside the battery rails. We'll see if it fits between wall of trailer and propane cover. Will probably be close like your set up.
Yes, I drink the water!
NJKris is offline   Reply With Quote
Old 11-11-2018, 01:33 PM   #23
NJKris's Avatar
Jay, thanks so much for pics of your set up.
Old 11-11-2018, 10:28 PM   #24
Glad to help, I did mine that way to get 3 group 31 12volt batteries to fit. The box in the picture on the tailgate looks sturdy. Is that why you plan to use it instead of 2 of the standard “marine “ boxes? I bet you are excited for tomorrow to pick up the new camper! Jay
Old 11-12-2018, 06:25 AM   #25
NJKris's Avatar
Jay, it's like Christmas morning! It's 22 degrees here, everything is white with frost, and while the grown up (my wife) still sleeps, I am up, remembering I have to cut some branches above the driveway so as not to scratch my new toy when I bring her home!
Yeah, that's a commercial grade NOCO battery box, with a lid that screws down with a couple thumb wheels. Just seemed easier than messing around with straps and such. I probably could have saved 40 bucks plus 20 bucks of mounting hardware if I just used individual cheapo 6v battery boxes, but I figure this is my 'vacation home' why not treat it to something a little better.
Old 11-12-2018, 06:50 AM   #26
I believe that today is “the day”. When you get it home, please post a picture of the battery box set up installed. Good luck today! Jay
Old 02-18-2019, 06:17 PM   #27
Originally Posted by DGrissom View Post
I have a 19FD and replaced the single 12v. battery with dual 6v. batteries.
I bought one of these and it fit well between the rails.
https://allbatterysalesandservice.co.../view/id/16102
It was too tall to fit in the space. I had to cut an inch off the top lip of the box to get it to fit vertically. The front of the trailer curves toward the battery and restricts the height. Note: Cutting the battery box worked fine.
Note the 6 volt batteries are plenty small enough. However, the height of the box could be a problem?
Any build/finished product pics?
2020 Rockwood Mini Lite 2506S
stevenc is offline   Reply With Quote
Old 02-18-2019, 06:37 PM   #28
NJKris's Avatar
Jay, sorry I never followed up with pics of final install. Here's mine:
ID:	197090   Click image for larger version
Old 02-22-2019, 09:12 PM   #29
Thanks for the pictures. I like the looks of what you have done. Jay
Old 02-23-2019, 10:29 AM   #30
NJKris's Avatar
I cut a couple little blocks and drilled through them to sandwich between the leading front corners of the box and the square metal girders I installed, so when I tightened the front bolts they would have something to tighten against.
Old 09-22-2020, 10:53 AM   #31
NJKris,
Can you tell me what the largest height and width battery box can be for the 19FD? We pick one up next week and I need to order a minimum of 44 inch box but I am not sure how tall and how deep I should limit it to.
AVeg is offline   Reply With Quote
Old 09-22-2020, 01:25 PM   #32
NJKris's Avatar
My box is 13.5" tall at highest point on lid, and 12.5" measured front to back. As mine does not fit in between the battery rails (it is on top, with a board in between the rails to support it), I had to trim part of the cover on the trailing edge of the box (Dremel tool good to have for this) to make it fit, due to the curvature of the front of the trailer. I also had to move the propane tank platform forward a bit (drilled some new holes, no big deal). The propane tank cover is pretty friction fit between the power jack and the battery box lid now. It does take some slight bending of battery box lid and wrestling the propane cover a little to remove either cover, but it works. Thankfully there is an access door on top of propane cover to reach valves, so I seldom remove propane cover. It's been 2 years since I got the trailer, and finally spent the first propane tank. I try to use electric heaters when needed, and do a lot of my cooking outdoors. I have made many pots of coffee on the range top, and baked a bunch of stuff in oven so far.
Old 09-22-2020, 02:20 PM   #33
Thank you so much. That helped me make a decision on the box. We ended up going with this one.
https://www.amazon.com/gp/product/B0...KIKX0DER&psc=1
I have read a lot of your post and have appreciated all of the information you have shared. I cannot wait to start our journeys with our 19FD.
battery
