04-06-2021, 04:32 PM
Geo Pro Frame Size
Does anyone know the frame dimension on a 19FBS Geo Pro? Looking at Anderson Weight Distribution and want to know what frame brackets I will need.
04-06-2021, 05:40 PM
If you are asking about the dimension of the framing it is 1" square.
04-06-2021, 06:31 PM
Thank you for the great video! I should have been more descriptive in the original post. I'm looking for the size of the frame where the weight distribution hitch brackets mount.
04-06-2021, 06:39 PM
Moved to Rockwood sub-forum because OP is asking for brand-specific information.
04-06-2021, 08:35 PM
The ones that come in the kit will work fine. I believe they are 3/4/5" brackets. I got the 3350 kit and have zero complaints about the Andersen hitch. It's quiet, easy to hook up and take off and doesn't weigh nearly as much as other WDH systems.
2022 Freedom Express 257BHS
2018 F-150 XLT w/3.5L EcoBoost and Max Trailering Package
04-07-2021, 02:26 PM
The frame on our 2020 Flagstaff E-Pro E19FBS is made with 2"x4" tubing.
04-08-2021, 10:09 AM
Thank you! and I assume it's a 2-5/16" ball ??
04-08-2021, 10:22 AM
FYI, not sure if they are different but we just took delivery of our Geo Pro G20FBS and the frame is 5' not sure if the G19FBS is different.
I also use the Andersen WDH, you will be pleased.
Mark
04-08-2021, 10:38 AM
Yes, 2 5/16 ball
04-10-2021, 10:02 PM
Geo Pro Frame Size
I went out and measured my frame depth where my brackets are attached to the frame. I have a 2021 19FD Geo Pro with the BAL Norco frame. On mine, the frame is a 4” frame depth.
Long Life, Good story!
04-11-2021, 09:53 AM
I wonder if the 19's are a 4" frame and the 20's are a 5' like ours?
04-11-2021, 08:12 PM
I measured my 20BHS frame and it's 4".
04-11-2021, 10:23 PM
Strange....I’m going to check with FR, maybe I got an oddball....with a 5” frame.
Anyone else have a G20FBS that can measure the frame size... 4" or 5".
04-12-2021, 11:20 AM
Information I got back from Forest River this morning is that BAL cannot supply the needed frames for the Geo/E Pro's for some reason. They are now using LCI frames. FYI.
04-12-2021, 11:27 AM
blame it on COVID shortages... and record RV sales
2014 Shamrock 183
