04-28-2021, 09:28 PM
Open Space Wanted
Geo Pro G16BH Real World Tongue Weight
Looking at the 2021 G16BH and wanted to know how much of the 461 lb. hitch weight spec. would increase by when carrying two full 20 lb. gas tanks, battery and 31 gal. of fresh water. I'm sure this isn't all going to the tongue weight.
My 2018 Grand Cherokee Trailhawk V8 HEMI 4x4 with factory tow package is rated for 7,200 lbs., but the more important numbers are 720 lbs. tongue and 1,050 lbs. of combined occupant/cargo weight on the Jeep.
04-28-2021, 09:46 PM
Full propane tanks weights have been included in the dry tongue weight numbers for at least the past 5 years. Should state that on the website or brochure.
04-29-2021, 09:58 AM
Open Space Wanted
How about water weight? How much does that affect tongue weight?
04-29-2021, 10:38 AM
Always Learning
Run your numbers through this tool:
Estimating Tongue/Pin Weight from Dry Weights - TowingPlanner
As far as I can ascertain, it's hit or miss. I seem to recall quite a few where the propane tanks themselves are included but not with propane in them.
04-29-2021, 02:37 PM
By and large (a generalization), the freshwater tank is located very close to the center of the axle(s). So the axle(s) carry the weight with little or no change to tongue weight.
This makes sense for several reasons, not the least of which is weight and balance calculations for safety. Water weighs 8.3 pounds per gallon, so if the manufacturer were to locate a 30 gallon fresh tank in front of or behind the axle(s) center, that 250# of water could really upset the balance of the trailer. Were the water to be forward, it would possibly overload the hitch. Were the water to be behind the axle(s), it would create a dangerous situation where the tongue weight could be reduced so much that the trailer would become an evil handling monster.
Crawl under your rig...or the rig you're considering on the dealer lot...and see where the fresh tank is located. It's likely to be balanced on the center of the axle(s).
An exception: Once you get into really big rigs, water weight becomes a MUCH smaller percentage of the rig's overall weight. There is some flexibility on where the fresh tank can be located. But still, putting a 100 gallon fresh tank under a king bed in the bedroom on a fiver could still add over 800# of additional weight on the pin box, fifth wheel, and rear axle of the TV. That 800# would be a substantial percentage of the 2500 to 4000 pounds that should be on the "tongue" of that fiver.
Jim & Renee
2020 Jayco Jay Feather X-213
Every weekend boondocking in the National Forests or at Lake Vallecito.
04-29-2021, 05:01 PM
My last 27' TT had the water tank located a foot inside of the back bumper under the bed. It was an evil handling monster when filled and two bikes were on the back hitch. Could haul bikes only if the water tank was empty.
2019 Forester 2861DS
04-29-2021, 07:04 PM
Open Space Wanted
Originally Posted by ependydad
Calculators are helpful although it was a little under my manual calculation. Guess the only real way to measure is a scale.
04-29-2021, 07:07 PM
Open Space Wanted
Appreciate the additional good information and most useful in doing the math before buying.
I reached out to the manufacturer and told only the empty LP tanks weight are added to the hitch weight. The batteries aren't included in the hitch weight. Also told the fresh water tank was in front of the axle but no further information.
04-30-2021, 12:41 PM
Always Learning
Yep, the only real way is going to a scale and getting measurements. It's more intimidating than hard:
https://learntorv.com/weigh-rv/
Thanks for sharing what the manufacturer said. That's not the first time I've heard the tanks but not the propane are included in the dry weights.
05-01-2021, 11:23 AM
Tongue Weight
The sticker on my G19FD states the CCC is with fresh water tanks full and waste water tanks empty. I use the following to weigh the tongue of my trailer and believe it is accurate. Hope this helps!
2020 Geo Pro G19FD
2018 Ford F150 2.7L V6 ECOBOOST
