Old 03-09-2020, 11:56 PM   #1
Geo pro no hot water
I just got a Geo pro and canít get hot water.
Rock Padre is offline   Reply With Quote
Old 03-10-2020, 02:02 AM   #2
HONDAMAN174's Avatar
So a few questions- is the water warm or stone cold? Has it ever worked?
Just glad to get away
Old 03-10-2020, 01:46 PM   #3
tc cruiser's Avatar
Rock,
Make sure your shower miser handle is in the right position. If it is turning white from blue then the hot water is going back to the fresh water tank. What model do you have? Also refer to your documents on the water heater about operation in electric and gas mode.
Tom
2018 Flagstaff E-Pro 19 fbs
tc cruiser is offline   Reply With Quote
Old 03-10-2020, 03:29 PM   #4
Trailer Park Supervisor
NJKris's Avatar
If on electric, you need the inside switch on, AND the switch for the outer water heater compartment.
NJKris is offline   Reply With Quote
Old 03-10-2020, 10:27 PM   #5
Remove the panels from the pass-through storage compartment to get to the area under the bed. You can get to the backside of the hot water heater there. Make sure the bypass valve is closed, and the cold and hot water supply valves are open. If the trailer was winterized, it is likely the bypass valve is open and the cold/hot water valves are closed.
Is the trailer plugged in to electrical service? Are the propane bottles valves open? Are the switches for gas/electric hot water heater turned on as appropriate? (When I want quick hot water, I use both at the same time.)
Open the outside panel for the hot water heater, and press both the reset buttons at the same time there.
NavyLCDR is offline   Reply With Quote
Old 03-11-2020, 12:24 AM   #6
bikendan's Avatar
Until the OP comes back and provides more information, we're all guessing.
Equalizer WDH
Old 03-11-2020, 11:37 AM   #7
Grammar Pedant
67L48's Avatar
Seems like a windup to me. Zero details. Popcorn.
RV: 2018 Rockwood Mini Lite 2504S
67L48 is offline   Reply With Quote
