09-02-2017, 11:43 AM
grill mounted on side of camper
I'm getting a new 2109s and was wondering if the grill has burned anybody's coach.my current coaches grill is mounted on rear bumper.
09-02-2017, 11:49 AM
The other day I decided to burn the residue off my grill before storage, so I cranked it up to high and closed the lid. I forgot about it for maybe 15 minutes. That sucker was cranking! The side of the trailer was hot but undamaged. It probably wasn't any hotter than it would have been sitting in direct sun down south.
09-02-2017, 11:56 AM
In 13 years of being on various RV forums, I have NEVER read of that ever happening.
And personally using my side mounted Sidekick grill for 10 years, I can attest to no damage at all.
09-02-2017, 12:36 PM
thanks that's reassuring
09-02-2017, 03:03 PM
But don't be surprised if your new trailer has a warning sticker. Apparently FR is starting to put them on:
http://www.forestriverforums.com/for...ng-143454.html
2011 Traverse LT, 3.6L, FWD
09-02-2017, 07:54 PM
Yep, warning sticker not to grill under the open awning.
09-03-2017, 11:39 AM
Grammar Pedant
I came from the popup world. Nobody over there was worried about the side grills causing heat damage to vinyl and other plastic siding materials. We were always concerned about odors and grease that could impregnate those soft materials. So, the more rugged materials of a hard sided trailer should be perfectly fine.
Other than the awning, you should be good to go.
Good luck.
Former RV: 2018 Rockwood Mini Lite 2504S
09-03-2017, 04:59 PM
On a hot day, just put a sheet of aluminum foil on the bracket between the grill and trailer side. That will give you some protection for 1/2 cent.
Got are first TT, a 2017 2506S. TV, 2016 GMC Canyon Duramax Diesel Loving it!
09-03-2017, 05:34 PM
My only concern with the grill is the mounting. The rail on my Roo pulled out dropping my grill on the ground. By the grace of God I had turned it off a few minutes earlier and was waiting for it to cool down before putting it away. Got some long screws and now it's secure to a board on the inside of the wall. Yours may have a better attachment but check it out.
09-03-2017, 05:55 PM
Pull and strap the grill
My grill has a small cable and a clip to wrap around the handles to keep it away from the trailer. While not related to scorching the sidewall, We line the inside of the grill with foil to make cleanup easier. Do the burner top (don't let it tuck under by much, it will be in the flame. Line the bottom making a couple of grease holes in the bottom. Cleanup takes a minute versus scrubbing the crud out each time.
2018 Rockwood 2509S Mini Lite
Past: 1984 Road Ranger 20', 1988 Kit Companion
1984 Starcraft 24 foot popup
TV: 1999 Dodge 2500 Cummins 4x4
Honda EU2200i Generator, 300 Watts Solar
Ham Callsign KD7UM
09-03-2017, 06:44 PM
I must do this foil trick. Thanks, I should know better ! Lol
09-03-2017, 07:20 PM
Mine did the same thing on our prior Shamrock, but I caught it before the rail completely separated. That's the good news. Bad news was the grill was lit at the time. Current Shamrock has the bracket mounted to the bumper.
2015 Shamrock 23IKSS, Oyster shell
2019 Chev Silverado LT Z71 Ext. Cab, 4x4, 5.3L V/8
Reese Straight Line WDH, 2000W Honda Gen.
2 Old Town kayaks & 2 Boston Terriers - Zoey/Gonzo
Lar & Ruth
09-03-2017, 09:41 PM
We have a 2604ws - the only problem we have is the side shelf support has damaged the swoosh decal it rests against. The grill has not caused any problem at all.
Rockfossilman - Western PA
Rockwood UL 2604ws - 2013 F150 w/MaxTow
"I'm a man, but I can change, if I have to. . .I guess."
Red Green
"Quando Omni Flunkus Moritati"
09-04-2017, 03:00 AM
Have used one for several years and have never had a problem
ADKDAN
2020 CEDAR CREEK 29RW
2018 RAM 2500
09-04-2017, 09:26 AM
AKA: 'tiredTeacher
My table support has done the same thing. I wish I had put a piece of felt or something on the arm. Too late now. No probs with the grill. Use it several times each trip and put the awning out.
Wright and Penny
(with Fitz and Lizzie, the camping kitties)
Richmond, Va.
2010 Tundra 4X4 5.7L V8
2014 Rockwood 2604WS
Life is a cruel teacher. She gives the test first; the lesson then follows.
09-04-2017, 10:39 AM
If you are a serious griller, you will be disappointed by the grill supplied by FR. Your steaks will be well done before you even get grill marks on them.
That's what happens when the element is 2" below the grate.
Total garbage.
2011 Nissan Xterra V6
2016 Rockwood MiniLite 2306
Nights Camped 2016 [24]
Nights Camped 2017 [63]
Nights Camped 2018 [27]
09-07-2017, 01:40 AM
We were kind of leery at first about hanging it off the side, but got over that. Really like it and no problems getting too hot. Works fine for us.
2015 Forest River Rockwood Signature Series Ultra Lite 8289WS w/Diamond pkg.
2014 RAM CTD 6.7 Tradesman 4WD Auto Crew Cab Long Bed
Honda eu2200i generators
