Old 09-06-2024, 09:17 PM   #1
Has anyone put shocks on 19' GeoPro or ePro?
I have a 2020 GeoPro G19FD with the square tube Dexter axle (with rubber inside). I get a good bit of rocking and bouncing on almost all roads. Anyone know of any add-on shocks for these or similar single-axle units?
Thanks.
Outsider
2007 F150 w/5.4 V8 (& 373 rear gears)
2020 Rockwood Geo Pro G19FD
Outsider is offline   Reply With Quote
Old 09-07-2024, 06:02 AM   #2
Sky&Scuba
kendive's Avatar
Found this from 2021
https://www.forestriverforums.com/fo...er-235796.html
and
https://www.rv.com/archive/shock-the...absorber-test/
2022 F150 PowerBoost Lariat 4x4 502A
2021 Rockwood 2205S
Gone-15 F150 3.5 EcoBoost Lariat FX4 502A / 17 Grand Design Imagine 2150 RB / 15 Catalina 253RKS / 13 Flagstaff 25KS
kendive is offline   Reply With Quote
Old 09-07-2024, 06:46 AM   #3
what is your tire pressure set at?
many people look at the max pressure as being the recommended pressure
if it is bouncing ... you can try lowering your tire pressure
Tarpon Springs FL
2022 Salem 24RLXL
Aussieguy is offline   Reply With Quote
Old 09-07-2024, 06:54 AM   #4
Sky&Scuba
kendive's Avatar
I would think making the tire pressure lower would cause more side to side wobble and bounce and sway more than usual.
One reason I like the Torsion bar axle. I guess they don't do this on the Geo ePro?
But who knows.
2021 Rockwood 2205S
Old 09-07-2024, 07:48 AM   #5
when lowering pressure find the tire manufacture's pressure chart for the tire size
Tarpon Springs FL
2022 Salem 24RLXL
Old 09-07-2024, 05:53 PM   #6
Do It Yourselfer
wuffwuff's Avatar
Suspension help
I installed the "Lippert Road Armor" equalizers on our 35' TT this past summer. I did notice a difference in bounce and jerking. Inside items stayed on the counter and table. There was nothing hiding behind the slides to interfere with opening them.
2022 Alpha Wolf 26RL-L
It's Easy to take 'Liberty' for granted, When you have never had it taken from You!
wuffwuff is offline   Reply With Quote
Old 09-08-2024, 07:15 PM   #7
Chewman's Avatar
Tire Pressure worked for me
The original tires on my 2020 G19FD (Westlake) had a much lower PSI than the Goodyear replacements. With the Goodyears the trailer bounced a lot on our lousy CA roads. I talked to a very knowledgeable person at Goodyear and he told me the Maximum tire pressure is just that, the Maximum. I dropped the pressure down to 75 from 80 psi and it made an enormous difference.
Here is the Goodyear inflation chart.
Name:	Tire inflation chart.jpg
2020 Geo Pro G19FD
2018 Ford F150 2.7L V6 ECOBOOST
Chewman is offline   Reply With Quote
