02-23-2021, 12:51 AM
Have anyone change out the light bulb on all the side?
I was youtube on someone changing out all default light bulb which consume alot of power than LED bulb. Can someone comment on this if it does make a big differnce in power wise or to save battery?
If so what LED bulb you replace it with.
thank you
2021 Geo Pro 20BHS
2020 Tacoma TRD SPORT 4x4
02-23-2021, 02:05 AM
LED lights make a tremendous difference in power consumption. They consume 75% or more less energy. So if you use the lights while boondocking it will save battery power. (We tend to use battery powered/solar rechargeable lanterns.)
The replacement bulbs will depend on what light fixtures you have. You could take out one of the bulbs and an online search should find the correct LED. In our small tt, we ended up buying new fixtures because the covers had discolored and the cost was about the same.
2015 Dynamax REV 24TB class C
02-23-2021, 02:09 AM
I would expect that your 2021 GeoPro has LED lights. Does it not? You may want to check before considering replacements.
2019 Wolf Pup 16FQ - bought new 3/2020
2013 F150 5.0 STX SCab 4x4 SB/3.55 rear/tow pkg./36 gal. tank/1695 Payload/7350 GVWR
Andersen Hitch
02-23-2021, 02:15 AM
Thank you so I should be replacing all my bulb starting from outside to the inside? is this the way to go? replace them with LED?
or should I wait till they are dead?
thank you
2021 Geo Pro 20BHS
02-23-2021, 02:06 PM
The upside is you will use much less power with all led lights. The downside is it will cost you money. You might be waiting years for all the lights to burn out.
02-23-2021, 02:10 PM
got it!!!decision decision!!. do anyone know if the new 2021 geo pro 20BHS come with LED light all around or they are just regular light bulb?
2021 Geo Pro 20BHS
02-23-2021, 03:00 PM
It's LED lights throughout the trailer. All of the puck lights are LED and all of the outside lights are LED as well. I think the only normal bulb is the oven vent.
2021 Geo Pro 20BHS
2016 Tahoe LT w/Max Trailering Package
02-23-2021, 03:07 PM
If...
They are probably LED. Here is how to check:
If they are incandescent (what you called "regular") the lens will easily snap off if you pinch two sides. Then you can see the incandescent lamp.
If they are LED, the lens might not come off. If it does come off easily, you can see tha it's an LED. If it does not come off easily--don't force it--assume it's LED.
Another way to tell: An incandescent lamp with fully-charged battery is white; it gets redder with a low battery. LEDs come in two colors; blue-white or yellow-white. Their color doesn't change much with voltage.
Larry
02-23-2021, 05:11 PM
wow!! didn't know the new trailer got all LED light!! thank you so much!! I was thinking about changing it all out  saved me some time and money..
2021 Geo Pro 20BHS
02-23-2021, 05:13 PM
Thank you for the clearification... this helped..
2021 Geo Pro 20BHS
02-23-2021, 06:12 PM
Tundra 2014
LED
We boonrock and I changed all my exterior, about 15% of previous usage when checking w/ Kill-A-Watt meter.
02-23-2021, 11:58 PM
2014 Coachman Leprechaun 220qb
Changed to all led on all coach lights
02-24-2021, 12:42 AM
Camping the Natural State
I always change everything out to LED's, even my home.
2021 Rockwood Ultra Lite 2614 BS, loaded except slide awnings and 2nd AC. Towed by 2013 F150 EgoBeast Screw.
02-24-2021, 12:09 PM
LED Swap downside
After the swap, I continuously got dash messages saying that one or another light was failing or the trailer was disconnected. I found this and it solved my problem, however I'm still glad to have made the switch.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
You'll also find, or at least I did, that they don't shine as bright. I solved this by using foil tape applied to the back of the fixture and behind the LED, giving it something to reflect off.
