To combine posts #2 and #3:
There should be a switch somewhere inside your rig to apply power to the pads. The pads will then turn themselves on below 40 deg F and off above 40 deg. F. Note the 40 deg F is "nominal."
Turn the switch off and the pads won't do anything.
2011 Traverse LT, 3.6L, FWD
