Old 05-09-2017, 02:52 PM   #1
help for slideout D seal replacement
Have a Rockwood Forest River 8289 WS 5th wheel. Need help on replacing upper D seal on livingroom slide. Does anyone know if you have to replace the whole seal and wiper or can you replace just the D seal?
pvicic is offline   Reply With Quote
Old 05-09-2017, 03:16 PM   #2
dbarr's Avatar
I'm going to guess it looks like this.
'15 F150 Ecoboost Maxtow Scab '19 Keystone Laredo 225MK
Days camped 2019-36, 2018-24, 2017-46, 2016 -56, 2015-33,
2014-47,
Years camping....54
dbarr is offline   Reply With Quote
Old 05-09-2017, 04:18 PM   #3
yes, thats it!
Old 05-09-2017, 05:08 PM   #4
crunchman12001's Avatar
If it looks exactly like the picture, you will have to replace the entire D seal that is attached to the H seal . My Coachmen had a D seal that locked onto the H seal and was separate and replaceable.
That is going to be a pain in the ***** to replace. You will see it has sealant holding it to the exterior and staples holding it on inside. You will need to remove the interior staples and and exterior sealant before you can remove the seal.
I would gladly pay a service center $300 - $400 for that repair.
2015 F-250 FX4
Old 05-09-2017, 06:57 PM   #5
dbarr's Avatar
Exactly why it's still in my garage!
2014-47,
Years camping....54
Old 05-09-2017, 07:06 PM   #6
I did replace a side piece, but did not replace the top. There is no room to work. (Also gave the leftover new seals to the new owner.)
2015 F-250 FX4
Old 05-10-2017, 12:21 PM   #7
I have a 2809W 2013 Windjammer and the D seal did not have the wiper attached. The wiper was on the H seal. I think my terminology is correct. I ordered new D seal from RVUpgrades, removed a screw at each end, slid off the old and slid on the new and replaced the two screws. Piece of cake.
VMI'62
Edmund is offline   Reply With Quote
Old 05-10-2017, 06:06 PM   #8
If you need some sources for replacement gaskets, here are some:
Steele Rubber Products - Quality Crafted Automotive Rubber Parts and Weatherstripping
Uni-Grip Inc.
Custom RV*& Limousine Parts | Specialty Vehicle & Concession Products
veraken is offline   Reply With Quote
replacement, seal, slide
