Old 07-28-2018, 07:09 PM   #1
Help wanted
2011 rockwood signature ultra lite 8315 bss tag along no brakes on right side left side or slide out side work fine. I installed new magnets to right side checked and adjusted brakes just get humming noise trailer jacked off ground wheels still spin other side will lock tight today took parts off good left side magnets and hubs and put on right side still got nothing but hum pu brand new wire 14 guage from left side over to right side still just a hum . Have checked ground up on a frame and sanded for good ground disconnected in junction box left side to wire directly back to right side only still nothing but hum is best I can get from right side any ideas would be greatly appreciated
Bdawg is offline   Reply With Quote
Old 07-28-2018, 10:27 PM   #2
Can you make the right side shoes tight enough against the drum to drag pretty hard or even lock the wheel? Jay
Jay2504 is offline   Reply With Quote
Old 07-28-2018, 10:47 PM   #3
Check adjustment.
Michael & Fran Dilday (Baxter & Honey 2 Labs)
'18 Cedar Creek Champagne 38EL - '17 Ford F350 Lariat DRW w/Reese hitch - TST 507 Color TPMS - Garmin RV 770 LMT GPS
mwdilday is offline   Reply With Quote
Old 07-29-2018, 07:21 AM   #4
Yes if you take up adjustment on right side they will lock up
Old 07-30-2018, 05:09 AM   #5
Are the inside of the right side drums shined from the magnets? You could have too much gap from magnet to drum. Do the magnets float in and out? Jay
Old 07-30-2018, 05:16 AM   #6
jd50i's Avatar
Stop throwing parts at it you will end up broke and frustrated. Check voltage between good side and bad side, it could be a bad splice or chaffed wire that isn't allowing full power.
2016 F150 XLT 4X4 SCREW 5.0
2014 Grey Wolf 21RR
jd50i is offline   Reply With Quote
Old 07-30-2018, 10:54 AM   #7
Problem solved controller from factory wired wrong..... Thanks to all that tried to help !!!!
Old 07-30-2018, 11:00 AM   #8
jd50i's Avatar
Letting us know it was a new installation would have greatly helped.
2014 Grey Wolf 21RR
Old 07-30-2018, 11:23 AM   #9
Didn't know!!!!!! Was at dodge dealer two weeks prior was told everything checked out to outlet so didn't go back to truck being problem !!!
