Originally Posted by Sunseeker16
Different rig here but those temps wouldn't worry me.
Same here. I have noticed the underbelly usually stays eight degrees warmer than ambient even with a slight wind.
I have now run a heat duct to my underbelly for when getting down near or in the teens.
Even then I have the fireplace and LP heat on and try to set it so the LP comes on periodically. There is no magic number as it depends on temp and winds.
Mid to low twenties for extended periods I will be sure I have some water in the tanks and heaters on for the effects of the heated tanks warming the surrounding area.
Open a cabinet door near your low point drains if you have one. Can't hurt. I have mine wrapped with insulation. Does it help? Don't know but it can't hurt.
