10-03-2020, 03:59 PM
Old man RVer
How do you drain the hot wate tank?
I have a new Mini Lite 2104S. How do you drain the hot water tank -- from the plug in the bottom of it or from the "low point" drains on the right rear of the unit?
thanks.
10-03-2020, 04:15 PM
If it is a Suburban HWH you pull the plug (which is actually the anode rod). If it is an Atwood it should have a plastic plug that you remove. Note: you also open the low point drains when clearing the system/winterizing.
2019 RW 2902WS
2019 Ford F-150 CC 4x4 w Max TT
10-03-2020, 04:58 PM
Just as confused as you
Never drain your water heater through the low point drains. That is why there is a drain plug in the bottom of the water heaters tank. Any crud built up in the WH will be pulled into the water lines if you drain it through the low point drains. Atwood water heaters use a 7/8" 6-point socket , Suburban water heaters use a 1-1/16" 6-point socket.. Most people use a 6" extension and ratchet to pull the drain plugs.
Richard & Jill
10-10-2020, 10:05 AM
I installed an anode with drain feature and put a ball valve on it, so all I have to do to drain the heater is open the valve.
10-10-2020, 10:09 AM
Georgia Rally Coordinator
X 2 Later RJD
Traded 2015 30WRLIKS V-Lite
Days camped 2019 62
10-11-2020, 09:03 AM
Old man RVer
This looks great! Where can I get the anode rod with the drain feature?
10-11-2020, 09:54 AM
Me too.
I would like to know as well.
10-11-2020, 10:23 AM
I'd prefer not to have that drain fitting. By pulling the annode rod out , you visually see its condition and know if it needs to be replaced or not. Once I pull the rod out and drain the heater I just slide it back in half a thread until next spring. Or no threads at all so fresh air can get in there all winter.
TT: 2018 Coachmen Catalina
243rbs(rear bath) legacy edition
TV: 2022 Ram 2500HD Tradesman
10-11-2020, 11:08 AM
I remove the drain plug from the HW tank. If I remember, I'll shut it off on the morning of our last day so it's not too hot. I like to pull the plug before I drive home because of the round bottom it won't all drain out sitting still. More water and minerals will slosh out on the road home. Same with my fresh tank. I open the drain when I'm breaking camp.
Peace!
Dan & Rita D
10-11-2020, 01:23 PM
Originally Posted by aceinspp
X 2 Later RJD
X3
10-11-2020, 02:00 PM
X4 this is a great time for using camco wh flusher and rinsing it out well. I use the camco anode with the petcock and have been in the habit of draining the whole system down at the end of a trip. Haven't had a lick of probs with the system and on original camco anode setup after 6 seasons FWIW.
2016 Flagstaff 27VRL Emerald
14K Equalizer
2020 Silverado 2500HD CC 4X4 6.6L gas 3.73
10-11-2020, 03:20 PM
I use the anode with a drain so that I can easily drain it after each trip. At the end of the season it comes out for a proper flushing and inspection of the anode.
2019 RW 2902WS
10-11-2020, 07:08 PM
Exactly.
10-11-2020, 07:09 PM
I change the petcock valve out for a full-port ball valve and short brass nipple to the water drains outside of the cabinet.
NW Leisure TSA200 Tank Saver Anode https://www.amazon.com/dp/B000HYOUSC..._065GFbWV9N01A
