03-15-2021, 05:30 PM
How do you open this Cabinet on top of the TV?
Hi,
There is a cabinet on top of the TV. Inside there is the Teton HD WifiRanger device. I want to open that up and put in my mofi 4500. I tried looked everywhere but I do not see any screw on the side on the bottom. How do you even take this thing out? do I suppose to push some secret door for it to open? or slide it out somehow?
Anyone know how to open this will be great!!
2021 Geo Pro 20BHS
2020 Tacoma TRD SPORT 4x4
03-15-2021, 05:47 PM
Access by removing the Tuner to the left.
03-15-2021, 05:51 PM
Take that switch out and see if its built into it or in the space behind it.
TT: 2018 Coachmen Catalina
243rbs(rear bath) legacy edition
TV: 2022 Ram 2500HD Tradesman
03-15-2021, 05:56 PM
small gap for me to work inside? I hope my mofi 4500 will fit in there. Is that the only way to work inside of there?
2021 Geo Pro 20BHS
03-15-2021, 05:57 PM
taking the switch out will let me peek inside, but how do i work inside of there? I want to mount my mofi 4500 inside of there.
2021 Geo Pro 20BHS
03-15-2021, 06:00 PM
Curious,, You just joined in Jan. 2021 and you're a "senior" member already?
03-15-2021, 06:09 PM
yeah. because I have been fixing my trailer . heheheh. Trying to get this mofi 4G setup done right. Teton HD is a joke. Only a wifi ranger. The issues with people camping in Forest and area with no signal. Thats when the 4G LTE come in. This thing work pretty good.
2021 Geo Pro 20BHS
03-15-2021, 06:24 PM
My guess is thats not a cabinet. How big is this 4g thing you want in there?
03-15-2021, 06:33 PM
If you can't find screws or any other type of attachment that would allow you to open that panel, it should tell you that it's not a cabinet and not meant to be accessed. Proceed with caution.
You might try removing the tuner and then using an endoscope to see what's in there.
But you probably have figured that out already.
2015 Dynamax REV 24TB class C
03-15-2021, 10:15 PM
One of these days he'll go camping
03-16-2021, 12:53 AM
can i call forest river as to how to open that?? maybe their support line? i don't like that teton wifi ranger in there. a waste of space..
2021 Geo Pro 20BHS
03-16-2021, 01:11 AM
Are there any screws on that Teton face plate? If not, you might be able to pry open the faceplate.
That piece of wood doesn't look like it's made to be opened
03-16-2021, 02:42 AM
that type of paneling is usually very thin and just stapled from the other side around the edges, and can be easily pried loose, ... the paneling above my fridge was, and if it is it can be removed with just a screwdriver, SMALL pry bar or the likes, ... but also, if it is, ... once removed, you'll have to be prepared to reattach it with some other method since you can't re-staple it from the inside, ...
03-16-2021, 04:09 AM
+1 in agreement with removing the stereo unit on the left side. Faceplate just pulls straight off. There will be 4 screws holding it in. Take out those 4 screws and pull the stereo out carefully, unplug all the plugs from it and you'll be able to access inside the cabinet from that hole.
03-16-2021, 09:14 AM
I agree with the above post that it's stapled in and can be pried loose. You can use velcro to secure it back in place, if you don't want to mount it permanently.
Gotta go campin!
03-16-2021, 09:25 AM
That is piece of thin plywood that is stapled in place. You can remove it by carefully tapping around the edges to get it out. There are several options to reinstall it. I would be cautious as to how much electronics you put in that area as there is no air circulation and they can overheat. You may want to add some louvered vents on the face of the panel.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
03-16-2021, 09:42 AM
Over 400 posts in less than 2 months. He's too busy typing to go anywhere.
03-16-2021, 09:51 AM
Insert witty title here
You can edit your forum title in the control panel. I just gave myself a promotion. It was time.
2021 Transcend Xplor 247BH
Husky WDH with Sway Control
2021 Chevy Silverado 2500HD LT 6.6L V8 Duramax
Forever in my memory. Forever in my heart.
Laurie J. Wood 3/22/67 - 8/23/19
03-16-2021, 09:54 AM
Georgia Rally Coordinator
Just over 6 post per day. Not bad. Later RJD
Traded 2015 30WRLIKS V-Lite
Days camped 2019 62
03-16-2021, 09:58 AM
That "Senior Member" title is assigned automatically by the site software based on post count. He has LOTS of posts so.............
As stated, member title can be set by the member in the User CP.
