Old 09-11-2019, 09:36 AM   #21
SlowrideHD's Avatar
If you have room for the installation, two GC2 class 6 volt batteries (such as Trojan T-105 or equivalent) will give you a lot more amps available to use than two group 27 deep cycle 12 volt batteries.
2016 F350 CC Dually Powerstroke 4x4
2014 Cedar Creek 34RLSA w/Level Up
2007 HD Ultra Classic 103
USS Pyro AE-24 WestPac MM2 '71-'75
SlowrideHD is offline   Reply With Quote
Old 09-11-2019, 12:01 PM   #22
FYI, this comment from Anthony Yoder, the Rockwood sales rep, in response to a query from me about the size of the tray:
Sent: Wednesday, September 11, 2019 12:14
Subject: Re: Mini-Lite battery rack?
"... The battery tray is intended to carry two 6 v batteries and we have not heard of any issues with two fitting, regardless of brand, type, etc."
TV: 2021 Ford F-150 4WD XLT Crew w/ 3.5L EB & HDPP, payload: 2,416#.
Camping nights: 2021, 52; 2022, 99; 2023, 88; 2024, 57 YTD 8/18, EOY est., 90+
chriscowles is offline   Reply With Quote
Old 09-14-2019, 11:07 AM   #23
Grammar Pedant
67L48's Avatar
That's been debunked here plenty of times. You can find 100-105 AH Group 27 12 VDC batteries. The Trojan T-105 is 220 AH. So, yeah, the 2x6 V will give you 5-10% more AH than the 2x12 V. Is that "a lot more amps"? That's sort of subjective.
  • 6V at 220 AH * 2 = 12V at 220 AH
  • 12V at 100 AH * 2 = 12V at 200 AH
This flips around if you go with a Group 29, which isn't that much larger of a footprint. I think I ran a 115-120 AH Group 29 with my old trailer. That (doubled) would have given me a bit more than 2x6. But, I'd still question if it were truly significant.
There are lots of reasons why 2x6 might be a better option. Footprint, maybe price, maybe maintenance/durability, etc. Capacity, though, generally isn't one of the reasons ... unless you are comparing the best 6 VDC battery (Trojan) to the crappiest 12 VDC battery (Walmart, e.g.).
Here is one example of a Group 27 battery rated to 115 AH. Doubled gives you 230 AH, which is more than 2x6V T-105. It is as good of a battery? I very much doubt it. The Trojan will probably outlast it several times over and there may be other advantages to the 2x6. But, capacity isn't necessarily one of them.
Former RV: 2018 Rockwood Mini Lite 2504S
67L48 is offline   Reply With Quote
Old 11-07-2019, 06:50 PM   #24
Just got a 2020 2109s and it had 2 deep cycle batteries in the box .
MedicJim is offline   Reply With Quote
Old 11-07-2019, 07:34 PM   #25
frank4711's Avatar
Watching .... good info ... thanks
Frank & Cindy--- (SOB) 5th Wheel ---2019 Ram 3500 Cummins 6.7 SRW 4x4 8' bed--- Payload 4394------Remi & Sage camping pups---TST 507 TPMS ... B&W Patriot 18K---3.73 axle ... Predator 3500---2019 48 days ---2020 28 days Camping
frank4711 is offline   Reply With Quote
Old 11-07-2019, 08:05 PM   #26
Flybob's Avatar
Are these true deep cycle batteries or marine dual purpose.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 11-07-2019, 08:48 PM   #27
[QUOTE=Flybob;2217786]Are these true deep cycle batteries or marine dual purpose.[/QUOTE
Marine didn't expect 2 as it was
Old 11-07-2019, 10:19 PM   #28
bikendan's Avatar
That was the dealer's decision. Some dealers do install two batteries on TTs. Most only install one. Almost all are cheaper dual-purpose marine batteries, NOT true deep cycle batteries.
I'm betting that's you have. If it has a CCA rating, it's not a true deep cycle.
Old 11-07-2019, 10:51 PM   #29
SlowrideHD's Avatar
Debunked?
I have years of real life experience with a remote solar operation in an off grid cabin. I have used well over two dozen group 27 deep cycle batteries of different brands and in different configurations over the years.
Currently running sixteen Trojan T-105 batteries in a 8S-2P configuration fed by 12 solar panels in a 3S-4P config for 3.3kw of power to my MPPT charge controller.
You can add and multiply numbers all you like and jot them down on paper....I know what works well. BTW....T-105 are 225 Amp.
Old 11-08-2019, 09:58 AM   #30
Grammar Pedant
67L48's Avatar
Debunked?
Correct. Debunked. Remember that I'm not talking about anything but capacity. You seem to have conflated a bunch of other battery system attributes into your response.
The concept of 2 * 6V having much greater capacity than 2 * 12V has been debunked many, many times. It's simple math and my post was 1-dimensional about that one attribute of the system.
All of the rest of your post speaks to durability, quality, and other attributes. There may be many reasons why a 6V bank is better for a person's needs. However, capacity in AH isn't one of them. The AH capacities of 2-battery systems are about the same ... unless you get small, crappy 12 VDC batteries. Good Group 29+ 12V batteries will have 100-120 AH and compare favorably to 6V batteries for capacity.
210, batteries, rockwood
