Old 06-18-2020, 09:11 PM   #1
How Remove Minilite Ceiling Lites
Hi folks, can you tell me how to remove the round ceiling lights in the Minilite? I'm guessing the plastic lens either pops off, is not removable, or twists off. I don't want to damage it. Perhaps the entire light pulls down but am guessing the plastic lens can be removed to reach the light itself. thanks
2205S Rockwood
F 150 Lariat 3.5 Ecoboost Fx4 Max Tow
Equalizer WDH
flyflotrtim is offline   Reply With Quote
Old 06-18-2020, 09:12 PM   #2
They screw off.
2018 Rockwood 2109S
Sahall is online now   Reply With Quote
Old 06-18-2020, 09:21 PM   #3
dbledan's Avatar
Yup counter clockwise. Be sure not to lose the button when you take it off.
dbledan is offline   Reply With Quote
Old 06-18-2020, 09:32 PM   #4
Does the entire lens turn or just the button in the center?
2205S Rockwood
Equalizer WDH
Old 06-18-2020, 09:35 PM   #5
dbledan's Avatar
Whole thing. Just grab the ends and twist.
Old 06-18-2020, 09:52 PM   #6
thanks all. Kudos to you and the forum.
2205S Rockwood
Equalizer WDH
Old 06-19-2020, 08:37 AM   #7
Are these already led, or the old light bulb type?
Signguy13 is offline   Reply With Quote
Old 06-19-2020, 12:48 PM   #8
Twist slightly
dwolff is offline   Reply With Quote
Old 06-19-2020, 02:12 PM   #9
2plus1's Avatar
SignGuy, The one pictured is an LED light.
Paul
Paul / Carole Ann and 'Monte' the Goldendoodle
2020 Rockwood Mini Lite 2511S
2017 Rockwood Mini Lite 2502KS
2005 Tiffin Allegro Bus 40TSP
2012 Ram 2500 6.7L Diesel
2plus1 is offline   Reply With Quote
Old 06-19-2020, 05:00 PM   #10
I replaced all of mine with an almost identical fixture but with warmer light (3500K) and a button that glows soft green in the dark. One other observation: Forest River used sheet metal screws that were too large in diameter (appear to be #8) for the thin ceiling material and the hole in the ceiling is marginally too large and one or two of the original too large screws break through the margin of the hole. The new light fixtures included smaller diameter screw and they do a far better job of securing the fixture to the thin ceiling.
Forest River Flagstaff e-pro 14fk
Ford Escape Turbo
Sarahcat is offline   Reply With Quote
Old 06-20-2020, 08:26 AM   #11
DunnDeal's Avatar
We are glad you posted this....At first we didn't even know that we had a center on/off button switch and now we know how to remove the covers
Charlie
2020 Forest River Rockwood Mini Lite LT2104S
2016 Ford F-150 Crew Cab XLT Truck
WDH: Husky Centerline
DunnDeal is offline   Reply With Quote
Old 06-21-2020, 01:46 PM   #12
Yup, they come right off now I know I can put a bit of pressure to turn them. thanks all
2205S Rockwood
Equalizer WDH
Old 11-03-2020, 03:13 PM   #13
QUESTIONS: Is the lens actually threaded or just a quarter turn counter clockwise to release and remove lens? THANK YOU
l001952119 is offline   Reply With Quote
Old 11-03-2020, 04:32 PM   #14
The lens doesn't have threads, just some tabs that lock into the metal ceiling piece to hold it in place.
2020 Flagstaff Micro Lite 22FBS
Wiscampsin is online now   Reply With Quote
Old 11-03-2020, 05:30 PM   #15
Please share a link of the lights you installed. The OEM lights are too bright and I've been thinking of changing them out to a softer brightness.
Famoussenior is offline   Reply With Quote
Old 11-04-2020, 01:10 PM   #16
Thank you! Since my post, I forced the plastic lens in a counter clockwise turn and the lens fell off! As you stated, just approximately four small tabs hold the lens in place. When replacing lens, you MUST line up the center slot on the lens with the center switch. I am headed to my RV dealer today in an attempt to identify and order a few light fixtures. IF I identify the part number, I will post in this forum.
lite
