Originally Posted by erm626
I have heard from different Rockwood owners, that the interior water filter has a leaking problem. Whether the O ring is defective or it is in need of grease or silicone. Many of those complaining are removing the filter all together. I was told they add a 2" PVC union in line and go with the outside the trailer Blue filter. Has anyone else been dealing with this problem ?
I have not had an issue with mine leaking but have read the same thing. However I left mine in for many years and had a different issue with dropped water pressure when using a filter, so I stopped using filters for a long time. then I decided one day I had the energy to remove the point of failure and put in a PEX coupler after cutting out the water filter. Mine was more like 4-5 inches but you're just replacing whatever you cut out. PEX requires special tools unless you buy the alligator couplers, then they just snap on.
"Take The Road Less Traveled"
2020 Cherokee 294BH
2021 Chevy Silverado 2500HD 6.6 Duramax Diesel
I've been an RVer since 2007, Lifetime Camper
Gotta love the Outdoors, Disconnect and Enjoy Nature!
