Old 05-04-2018, 08:18 AM   #1
IRV system
The “entertainment system” in my 2504 keeps turning on all by itself. Any idea what is causing this or how to stop it?
2016 Rockwood 2504S
2006 Ford F150
Garrett717 is offline   Reply With Quote
Old 05-04-2018, 09:35 AM   #2
Some others have reported this. You might want to do a search via the search field at the top of the page.
Only fix I can recall reading about was installing a switch in the power line.
Maybe someone else will chime in.
2011 Traverse LT, 3.6L, FWD
Old 05-04-2018, 09:54 AM   #3
jeff64's Avatar
From the vintage of your trailer, I guessing iRV66. Those were troublesome to say the least. I've replaced mine 3x. Don't think you'll get anywhere with Patrick Ind. But, maybe Jake Carter at FR cust. serv. will cut you some slack.
Good Luck!
2016 Flagstaff 27VRL Emerald
14K Equalizer
2014 GMC 2500HD CC 4X4 6.0L
Old 05-04-2018, 10:04 AM   #4
Ours did that and I finally figured out that there was a wake up alarm that was 'waking up' the entertainment system instead of waking us up because it was set for an odd time. Unfortunately, I can't tell you how I turned it off. I just kept pressing buttons until I found the alarm.
2015 Dynamax REV 24TB class C
Reverse_snowbird is offline   Reply With Quote
Old 05-04-2018, 11:16 AM   #5
Thank you. We are heading out for the weekend. I will see if I can figure out the alarm. On the on other hand I have found it on three times this morning. I may end up cutting the power to it for the weekend
2016 Rockwood 2504S
2006 Ford F150
Old 05-04-2018, 12:30 PM   #6
That was the 'snooze' alarm on ours. I turned the sound to 'mute' many times before I figured it out. In my rig, I couldn't cut the power to it without cutting the power to something else.
Have a safe trip.
Old 05-04-2018, 12:49 PM   #7
jeff64's Avatar
Great that you solved it. Don't think I ever messed with the clock or alarms
14K Equalizer
Old 05-05-2018, 05:32 AM   #8
I dug out the manual. This thing is an iRV33. The manual does not show any kind of alarm clock. So does anyone have any other ideas why it would suddenly turn itself on. Interestingly it has never happened while we are in the camper.
2016 Rockwood 2504S
2006 Ford F150
Old 05-05-2018, 05:59 AM   #9
Locky's Avatar
Well then there is no doubt......your camper is haunted.
2018 Rockwood 2906WS
2013 Chevy Silverado
1967 Beautiful Wife
Locky is offline   Reply With Quote
Old 05-05-2018, 07:51 AM   #10
Well then can you suggest a good exorcist
2016 Rockwood 2504S
2006 Ford F150
Old 05-05-2018, 10:27 AM   #11
Mine's an iRV33, too, but I've never had any issues with it.
But I will say that the owners manual isn't worth the paper it's printed on.
Old 05-05-2018, 03:50 PM   #12
Locky's Avatar
Linda Blair has some experience....
1967 Beautiful Wife
Old 05-05-2018, 11:10 PM   #13
RangeMaggotBob's Avatar
I also have that system, though I think mine might be the IRV66. Anyway, they are all just plain old pieces of crap. it's probably the cheapest thing they put in our trailer. I can't remember the issue, but I had nothing but good service from Patrick Industries. Bypassed FR and my dealer. One thing I did have to do was disconnect the junky FM antenna on our trailer and split the coax coming from the roof antenna and ran the cable to the antenna input on the receiver. At least now the FM part gets good reception. And the DVD player on ours never has worked right. A new REAL audio/visual system is rapidly moving it's way up on my wish list.
2015 Forest River Rockwood Signature Series Ultra Lite 8289WS w/Diamond pkg.
2014 RAM CTD 6.7 Tradesman 4WD Auto Crew Cab Long Bed
Honda eu2000i generators
RangeMaggotBob is offline   Reply With Quote
Old 05-07-2018, 09:23 PM   #14
Newbie
Had an irv33 unit in my mini lite that didn’t work properly from day one. Some days it worked, some it didn’t. Finally just quit working about 3 months out of warranty. Replaced with a Jensen unit from etrailer.com and couldn’t be happier. The Jensen seems to be a much better unit.
How 'bout them Cowboys!
2015 Rockwood 2104S
2013 F150 4x4 EcoPuller
okiecowboy is offline   Reply With Quote
irv
