Old 06-02-2018, 07:10 AM   #1
tdidad's Avatar
Leaking Toilet Signature 8328BS
Seems the water is going somewhere. Our trailer is parked this season at a local campground, we go there on the weekend. I always make sure there is a couple of inches of water in the toilet bowl when I leave...when I return the bowl is dry, water gone? Maybe a seal? Easily repaired? Weve only taken delivery of it mid April.
Thx!
17 Rockwood Signature 8328BS
tdidad is offline   Reply With Quote
Old 06-02-2018, 08:46 AM   #2
nomad297's Avatar
Put some latex gloves on (or not) and rub the black gasket clean between your thumb and forefinger before you decide to go all-out and replace the gasket. Don’t pinch so hard that you pull the gasket off.
Bruce
Old 06-02-2018, 08:54 AM   #3
tdidad's Avatar
Originally Posted by nomad297 View Post
Put some latex gloves on (or not) and rub the black gasket clean between your thumb and forefinger before you decide to go all-out and replace the gasket. Dont pinch so hard that you pull the gasket off.
Bruce
Thx Bruce, Ill give it a whirl!
Old 06-02-2018, 07:51 PM   #4
mudman2's Avatar
Thx!
Evaporation?
2019 microlite 25bds
2015 tundra
mudman2 is offline   Reply With Quote
Old 06-02-2018, 08:56 PM   #5
Put 6 inches in it. If it's gone, it's leaking. If there's still some there, it's evaporating.
2011 Traverse LT, 3.6L, FWD
Old 06-03-2018, 05:09 PM   #6
Toilet problem
Yes, the good hold vaseline will do the trick.
Clean the O ring and apply vaseline on it and it is good as new!
Jonol is offline   Reply With Quote
Old 06-05-2018, 04:06 AM   #7
nomad297's Avatar
Did you work it out?
Old 06-05-2018, 08:16 AM   #8
tdidad's Avatar
I think I did, I reset the seal then filled the bowl 6.
Ill check it again when I go back this wknd.
Thank you (all) again for the advice.
leak
