Old 09-13-2024, 09:35 AM   #1
Lippert Electronic Stabilizer Issue
Recently, I've run into a recurring problem. I can extend one set of my Lippert electronic stabilizer, but to extract (bring back up) I have to hit the button/switch repeatedly, and eventually is comes up. My guess is that trick will eventually stop working.
I know I can manually bring it up --- but I find this disturbing. I've read all sorts of things like bring up manually so it "resets" itself, or replace the switch (the newer switch has a rain cover).
The dealer said it could be the motor. They could replicate it, so of course they didn't fix anything. I don't think they tried very hard to replicate it.
I'm going out next weekend and if it continues, I'll try the manual approach, which I read sort orf the stabilizers. Could be horseradish, but worth the try. Replacing the switch looks relatively easy. A new switch was only $40 or so.
Has anyone experienced this? Ideas?
_______________________
2022 Rockwood Mini Lite 2511s
2020 Ford Expedition XLT - Max Towing
jsk125 is offline   Reply With Quote
Old 09-13-2024, 09:47 AM   #2
Have you done any voltage tests with a meter at the switch or the motor when it does not work?
Throwing parts at something is never the proper approach to a repair.
Days Camped '19=118 '20=116 '21=123 '22=134 '23=118 '24=101
Old 09-16-2024, 05:49 AM   #3
Check the switch. Clean contacts and inspect for failed parts
2022 Rockwood Ultra Lite 2608BS
2014 Dodge Ram 6.7
MrPukaShell is offline   Reply With Quote
Old 09-16-2024, 05:01 PM   #4
Thanks ...
FYI the part was cheap, always good to have an extra. I'll test this coming weekend and clean the existing switch.
Old 09-16-2024, 07:25 PM   #5
I have a 2021 and both switches went bad one last year and the other this year I assume they had a problem because the old ones were no longer available they were updated and the new ones are larger
G37x is offline   Reply With Quote
stabilizer
