Closed Thread
Old 04-06-2021, 07:39 PM   #61
Old man RVer
Shutoff valves on low point drains
I put shutoff valves in my low point drains. Works fine.
2WheelJon is offline
Old 04-22-2021, 01:46 PM   #62
Originally Posted by rracer5 View Post
Are you sure there aren't shut off valves already hidden someplace....perhaps behind a panel? I can't believe it came with just caps! You're going to get drenched taking the caps off of pressurized lines.
There are no shutoffs on low point drains, why would there be, they are drains. Who would remove a cap on a pressurized system, would you remove your water hose while the water is still on? Look and see if there are rubber washers on the cap like there are on hose connections, if not go to the hardware store and buy two the size you need.
Jcape is offline
Old 04-22-2021, 02:58 PM   #63
Just as confused as you
Scrapper's Avatar
Have you ever heard of the concept of convenience, as it's convenient not to have to worry about loosing the rubber washer or cap.
Richard & Jill
Scrapper is offline
Old 04-22-2021, 03:29 PM   #64
DouglasReid's Avatar
Do you worry about losing your fuel cap whenever you fill your vehicles, or your lawnmower, or your generator, etc?
That is a very weak argument.
Ive had caps on the low point drains and never ever lost one. I simply set it nearby so that it was "Convenient" when I got done draining the system.
I admit, ball valves are more handy and in fact easier. That is why I simply put my Big Boy pants on and installed them on all those drains.
2009 Chevy Silverado 2500HD CCSB LTZ Diesel, Fumoto Oil Drain Valve, Turbo Brake activated, 39 gal Aux Tank W/ Fuel Pump transfer, Air Lift Loadlifter 5000 air bags.
DouglasReid is offline
Old 04-22-2021, 03:40 PM   #65
KyDan's Avatar
I can't believe you grown up men are arguing over this topic!
Sheesh....
Thread closed in the hope of preserving forum harmony.
Peace!
Dan & Rita D
KyDan is online now
Closed Thread
drain
