03-30-2021, 07:49 PM
Low point drain caps dripping
We took out our trailer for the first time this year. Noticed dripping coming from low water drain caps. Hand tightened even more. Leak stopped and then noticed 3rd morning leaking again. After driving it home noticed once again they were wet. I take it these stupid screw on caps are pretty much worthless. Anyone experience this and was your fix installing ball valves/Teflon tape to the cold and hot low point drains?
2019 Ram Big Horn 6.7 Cummins
2020 Rockwood Ultra Lite 2304DS
03-30-2021, 07:58 PM
Are you sure there aren't shut off valves already hidden someplace....perhaps behind a panel? I can't believe it came with just caps! You're going to get drenched taking the caps off of pressurized lines.
2014 Prime Time Sanibel 3250
03-30-2021, 07:59 PM
I've seen dripping from these and found the rubber seal/washer to be missing... as if it fell on the ground the last time the cap was removed.
03-30-2021, 08:01 PM
My Wildcat came with only screw on caps. I have never removed the caps while the lines were pressurized. Why would you?
Replaced our caps with threaded ball valves but was disappointed to see a leak on the cold side. Took the valve off and used Teflon tape and so far so good. Plus having the valves makes it easier when it comes time to winterize.
03-30-2021, 08:04 PM
I lost a washer on mine the first time out, and couldn’t find a replacement for the white, cone shaped one. I brought the cap to Home Depot and found a plain black washer that fit and it works fine.
Yes, a lot of people put valves in these. I haven’t found one easy enough to turn at the awkward angle.
Carmen and the pack
2015 Coachmen Clipper 17BH
2017 Dodge Durango Citadel 5.7 Hemi
03-30-2021, 08:09 PM
Yeah I am sure. They are caps for the low water drains
03-30-2021, 08:10 PM
I removed them when I winterize my trailer. I do it every year.
03-30-2021, 08:11 PM
I may have inadvertently lost the washers while winterizing last fall. I will have to check tomorrow see if the washers are even in the caps
03-30-2021, 08:12 PM
03-30-2021, 08:14 PM
How tight did ya have to go on these drain caps?
03-30-2021, 08:38 PM
But surely you don’t remove them while the lines are still pressurized.
03-30-2021, 08:42 PM
No why would I? I removed them this past November to drain water while winterizing. Took the trailer out for the first time this year and noticed the caps were dripping.
03-30-2021, 08:46 PM
You quoted my post where I said “I have never removed the caps while the lines were pressurized”. I guess that confused me.
03-30-2021, 08:48 PM
That was someone else in the thread that posted that [emoji23][emoji6]
03-30-2021, 09:15 PM
Yes I have had the lines leak, tightened them down no issues rest of the season. When I winterized I replaced with valves, I thought the caps we a PIA and the washers were hard to keep in when taking off. Bought the valves at Home Depot. Threaded on easily.
2020 Flagstaff 26FKBS
2020 Ram Tradesman 2500 6.4 Hemi
03-31-2021, 04:33 AM
[emoji106]
03-31-2021, 07:18 AM
Brake is on left
You probably lost the seal. Or, it's no longer pliable. You can pick up a fistful from your local plumbing shop for the price of a coffee.
https://www.supplyhouse.com/Viega-43721-VIEGA-1-2-PureFlow-Cone-Seal?gclid=EAIaIQobChMIg5nhr8Ha7wIVS_HACh12HwB2EAQ YASABEgK4bfD_BwE
03-31-2021, 07:21 AM
Originally Posted by The Evil Twin
That is most likely the case. Will be heading to where my Trailer is parked after work to take care of this. I think I am just going to install the pvc ball valves on it.
03-31-2021, 07:39 AM
i lost one of the cone washers once and the cap leaked. take the caps off and ensure that you have a cone washer on each drain. it is the cone washer that makes the seal. no need to use teflon tape and you really only have to get the cap on hand snug. not need to torque it down.
2015 cardinal model 3825fl
2015 dodge ram 3500 dually
